    [Plugin] Random Painter (Updated March 9th, 09)
    73 Posts 23 Posters 118.4k Views 23 Watching
    • Chris FullmerC Offline
      Random Painter (Chris Fullmer Tools)
      Pretty straightforward. This script works by using the selected geometry and painting it. The user has to first choose the colors to be used from a color palette. This needs something called WxSU Ruby to work. So please download and install it first. Once the colors are input, the script finds all the faces and then paints them randomly from the previously input colors.
      The video shows how I use it, and it also shows how to use it with "Make Unique" and "Combine Textures" which are built into to SU version 7.
      [flash=812,612:21l5w7ia]http://www.chrisfullmer.com/forums/Random_Color.swf[/flash:21l5w7ia]
      After the 2:10 mark, I just show how to use Make Unique and Combine Textures, its not really about the plugin at that point.
      Also, known bugs: If you type in stuff other than RGB values, it might crash the whole script or else they will just get ignored and not paint anything on some faces. Also, I think I coded it wrong because the cancel button doesn't work - oops! I might have to go back and figure that out, because it should defintely work.
      Hope that helps, and dont pay any attention to my inability to type and talk in the video 😄
      Chris
      Download the required wxsu if you don't have it
      OR there is now a non-wxsu version included below. It is a little slower to use, but it works pretty good.
      v1.1
      No WxSU version
      All my Plugins I've written
      • G Offline
        gaganraj
        that is really cool. its like making procedural textures in modo or lightwave!
          Pilou, I have a feeling it is painting the other side of the face. I think it only paints the front side of the face.
          And to get out of the RGB input, just click ok with nothing entered in the boxes. If it applies color that you don't want, then undo it. I need to figure out better how to get the cancel to work right - sorry 😞
          Chris
            Amazing ☀
            Some connections possible with this script CheckerBoard Painting in developpment by Todd Burch?
            Don't work with this?
            Is that normal? (I had of course selected all facets 😉
            Even another figure 😮
            How do you make the first drawing?
            And only Alt +Ctrl + Del for stop 😉
              Another thing!
              That will be very useful too to apply the colors pallet without randomize! ☀
              By Orgelf
              http://i43.tinypic.com/rvzzae.jpg
                You absolutely right that work fine!!! 😎
                Just inverse faces and all works like a charm for any drawing surfaces!!! ☀
                Todd is defeated 💚 You are brutal with him 😄
                  Man that is very fun! 👍 👍 👍
                  Using Zorro2 is perfect!!! 😎
                  Now you must permit to choose between colors paletts!
                  Because it's very painful to enter by hand some colors!
                  Ruby technical state is ended, now artistic step begin 😎
                  Phone Todd to stop his script! 😆
                  • E Offline
                    Ecuadorian
                    Wow, thank you, Chris!
                    In a minute I'll show you what I wanted this for...
                    -Miguel Lescano
                      Todd is defeated! You are brutal with him 😄
                      No, its not like that. Todd's script does a lot more thinking than mine. His works so that every other face is painted to create a checkerboard pattern. Mine will do no such thing. Mine just randomly paints the faces. Both have their uses.
                      I know of a ruby add-on that gives a color wheel thing. I'm going to try and see if I can figure out how to get it to work with this plugin so you can use a color wheel to pick the colors instead of typing them all in by hand. I make no promises on this one though,
                      Chris
                      • E Offline
                        Ecuadorian
                        Here are a few more views:
                        And here's the thread that inspired this exercise:
                        http://www.sketchucation.com/forums/scf/viewtopic.php?f=72&t=15785
                        -Miguel Lescano
                        • E Offline
                          Ecuadorian
                          Both scripts are very different, each serves a different purpose. I am already thinking of a couple of creative uses for Todd's script, both related to Greeble... You have to see beyond mere colors and into the selection possibilities of these tools.
                          And Pilou, you don't need to worry about entering precise values when using "Random Painter". Just click on the Red box and input "1", hit Enter, then "2", hit Enter, then "3", until you have the number of colors/materials you want. And then replace those "placeholder colors" with Any Colour You Like, one by one, with the Bucket tool + Shift.
                          Almost forgot: Here's the SketchUp file of "Greeble City":
                          SketchUp 7
                          -Miguel Lescano
                          • MALAISEM Offline
                            MALAISE
                            Awsome, the way you do it Chris 👍 .
                            Ecuadorian, i like very much this city view ;thanks for the trick
                            Pilou, tu es un beta testeur de classe Alpha 😄
                            MALAISE
                              Thanks everyone! And wow!, that is a great usage for the script Ecuadorian! Maybe I'll play around with seeing if there is a way to use a folder of jpgs as the random materials instead of random colors. THen you could put all the building materials into a folder and just choose the folder and off it goes! But that might be over my head, I don't know.
                              But what I wanted to say was that I updated the script!
                              NEW!
                              Now there's a color palette for you to choose your colors from. It also lets you enter RGB values if you'd like. It does not allow for hex numbers though Frenchy, so no copy and paste still. This version requires WxSU plugin. So please install it and then install my plugin and see how it goes, hope you like the improvements. Also, I just added a prompt asking if you want to paint the backside of faces too. If your version doesn't ask that, then redwonload my plugin. It looked like a few people downlaoded the version that did not have that implemented yet.
                              Chris
                                linea
                                great script, thanks
                                  New York rebirth ☀
                                  WxSU Ruby is 2 649 742 size ? 😮 😮 😮 (as 2,6 Gigas?)
                                  Seems not reasonable loading 😄
                                    As 2.6 Megas.
                                    • K Offline
                                      kwistenbiebel
                                      Amazing stuff, Chris.
                                      This plugin comes in handy for an architecture project I am working on.
                                      Thank you very much ! 👍
                                        @ecuadorian said:
                                        This exercise was inspired by a $4,000 program for "parametric" generation of cities I saw on the web. I just wanted to prove that you can "random generate" cities in SketchUp, too. Thank you a lot, Chris, for delivering the missing link to make this possible.
                                        I saw that software as well. Played around with rubies to quickly generate some simple buildings.
                                        With all these various plugins, it should be possible to make a City Generator script which automates the process you just did. What would be more interesting is if there was a script to generate streets in a non-rectangular pattern. Seeing how nearly every city is more organic laid out.
                                          As 2.6 Megas.
                                          Many Thx! ☀ Seems more reasonable 💚
                                          I had asked that because loading was not working till yet for me 😞
                                          Edit : works 😄
                                          • K Offline
                                            kwistenbiebel
                                            This is how I am using the plugin.
                                            http://i140.photobucket.com/albums/r3/kwistenbiebel1/fragment1-1.jpg
                                            • 1 / 4
