    [Plugin] FollowMe and keep (v0.04 update 20090210)
    223 Posts 79 Posters 223.9k Views 79 Watching
    • W
      wikii
      FollowMe and keep the dirction of profiles.
      Tip:construction point in selection will be treated as the align_point!
      v0.04 20090210
      1 if path started at a vertex of profile,the vertex will be treated as align point.
      2 auto reverse face to get directviewing result.
      v0.03 20090209
      1 start at nearest vertex when path is closed
      2 fix some bugs
      http://www.sketchucation.com/forums/scf/download/file.php?id=21147
      v0.02 20090208
      1 perfect ending;
      2 autosmooth.
      A example
      Gif demo,click it to see!
      v0.04
      v0.04 - I HATE .RAR FORMATS
      • S
        sepo
        Wow that was quick...I will give it a whirl... Thank you.
        • S
          sepo
          I dropped Fak.rbs into plugins folder but it does not show up.
          • R
            remus
            not sure if im doing something wrong but i cant see it in the plugins menu...
              Terrible!!! ๐Ÿ˜Ž
              PS Is it only for pro version? Because I see nothing on the Plugins menus free V6, V7 ๐Ÿ˜ฎ
              • S
                sepo
                Tried on the other comp... same thing.
                • W
                  wikii
                  open fak.skp,
                  follow the text in the each page.
                  • Jean-FrancoJ
                    Jean-Franco
                    could you help me ?
                    I don't see any FAK command in the plugins menu after extracting the FAK.rbs file in my Plugins directory.
                    Jean-Franco
                    • S
                      sepo
                      It does not show in plugins.
                      • R
                        remus
                        Wikii, if its any use this is what i get when i try and load it from the ruby console:
                        load "FAK.rbs"
                        Error; #<SyntaxError; (eval);131;in `load'; C;/Program Files (x86)/Google/Google SketchUp 7/Plugins/FAK.rbs;1; no .<digit> floating literal anymore; put 0 before dot
                        RBS1.0
                        C;/Program Files (x86)/Google/Google SketchUp 7/Plugins/FAK.rbs;1; syntax error
                        RBS1.0
                        C;/Program Files (x86)/Google/Google SketchUp 7/Plugins/FAK.rbs;1; Invalid char `\030' in expression>
                        (eval);131
                        • W
                          wikii
                          Sorry , I did't test it without Sutool.
                          I have posted the fixed version,please download it again.
                          ๐Ÿ˜ณ
                          • Jean-FrancoJ
                            Jean-Franco
                            Yes ! now it works !
                            thank you.
                            Jean-Franco
                              Works! ๐ŸŽ‰
                              • R
                                remus
                                Works like a charm, thanks very much ๐Ÿ‘
                                • Jean-FrancoJ
                                  Jean-Franco
                                  in scene3 we have this at the end for the smallest surface.
                                  Jean-Franco
                                  • W
                                    wikii
                                    Seems last at the end are false! ๐Ÿ˜‰
                                    You can add a hori line at the end of curve to avoid it.
                                      Not a big deal than you can erase it but... perfection is needed ๐Ÿ˜’
                                      • Jean-FrancoJ
                                        Jean-Franco
                                        I do not understand exactly the difference between the two first scenes.
                                        See below the top view when I selelect parallel projection.
                                        Jean-Franco
                                          Yes but it is some tedious ๐Ÿ˜‰
                                          Beauty is go to the end โ˜€
                                          The curious thing is all seems good till the previous module โ—
                                          • W
                                            wikii
                                            [attachment=0:14ocmtqc]<!-- ia0 -->FAK_test_scene1.jpg<!-- ia0 -->[/attachment:14ocmtqc]
                                            In the second scene,there is a construction point at start of the curve.
                                            ๐Ÿ˜‰
                                            • 11
                                            • 12
                                            • 1 / 12
