    [Plugin] Component Spray update
    29 Posts 16 Posters 51.0k Views 16 Watching
      troyhome
      I really appreciate the generosity with which you supply this community so many innovative tools. the dialogue that comes with your scripts is essential to improving SketchUp and how people interact with it.
      Thank you.
      IOviz.com
      SU Pro 2024 PC
        Sir
        this looks like an amazingly useful plugin. thanks!
        • dereiD Offline
          derei
          What means this update? If I want the latest version of the Component Spray, is it This One, or This one?
          Thank you.
          DESIGNER AND ARTIST [DEREI.UK](http://derei.uk/l)
          • Didier BurD Offline
            Didier Bur
            Latest version is here: http://rhin.crai.archi.fr/RubyLibraryDepot/plugin_details.php?id=76
            DB
            • dereiD Offline
              derei
              thank you very much ! ☀
              • brookefoxB Offline
                brookefox
                Dear Farmer,
                Finally I have an occasion, and finally I straighten my install and finally I harvest a moment of your efforts.
                Thank you, Farmer. You help make living in this valley a pleasure.
                http://img638.imageshack.us/img638/7831/compospray1.jpg
                ~ Brooke
                  brookefox
                  EDIT: This error may just be mine: perhaps having enabled 'hide everything else while editing group'.
                  There may be a limit on how far the routine likes to be 'buried'? That is, when I run it on a simple group, no sweat, but when I try to run it in group within a component, it seems to fail. Please see image. Top success within the group copied out of the component. Lower failure on the same group residing in the component. Perhaps I missed some advice in the use instructions. (Not an issue of overshadowing entities.)
                  I tried the same test in the naked group in the same location as the failing component and it worked fine, so it does appear to be that the routine wants to breathe a bit.
                  ~ Brooke
                    brookefox
                    When spraying grass components onto a large area and I want to keep the numbers down the lowest available setting of 1% is still very much too high, so I make a request for percentages below 1.
                    My work-round for this is to include within the component a large triangle so the spray density is thus limited and then edit this out of the component later. This works fine.
                    ~ Brooke
                      brookefox
                      Having a hard time now. Rarely is anything being sprayed, no matter the setting. No groups or components on the receiving end.
                      FloatDomainError?
                      ~ Brooke
                      • 2 / 2
