    Vray Problem
    6 Posts 3 Posters 1.8k Views 3 Watching
    • S
      smhbrv
      Hi everyone.
      When I want to download Sketchup 6 for Vray in Sketchup 7 , I have got a big problem.
      Vray gives a window and I dont see VrayForSketchup in Plugin.
      I do this every time. Firsty I install Sketchup 7 and then install Vray for Sketchup 6. But now It dont work.
      Can you help me Please.
      http://img88.imageshack.us/img88/9751/adszvz3.jpg
      • Chris FullmerC
        It looks like its also looking for a VRayForSketchUp.so file. I'm guessing you must have missed some files when you copied it from 7. So try the actuall installer file. If that doesn't work then probably best go to the Vray website and best contact them.
        Chris
        All my Plugins I've written
        • thomthomT
          Did you use the same installation file for both? There is an installer for both SU versions.
          • S
            smhbrv
            I use Sketchup 7 and I install Vray For Sketchup 7 , but When I right click on my object , There is no Sketchup For Vray.
            I can see in ''Plugin'' , but I dont see When I click the right with mouse , while on the object.
            This image is about Sketchup 6 and Vray For Sketchup 6.
            http://img84.imageshack.us/img84/5595/adszmk6.jpg
            And this is my problem. ( Last image.) How can you explain this ? I remove it , install again, but the same problem is continuous. This image is about Sketchup 7 and Vray For Sketchup 7. Thank you.
            http://img21.imageshack.us/img21/2603/adsz33qy0.jpg
            • thomthomT
              The image from SU6 is using an old V-Ray for Sketchup version.
              The image from SU7, is a newer V-Ray for Sketchup version. V-Ray materials are automatically linked now. Find the corresponding material in the V-Ray material list.
              • S
                smhbrv
                What does it mean ? Can you explain more than this ?
                Please tell me with picture. Because my english not good 😞
                Thank you.
