    Collaborative Effort - Ruby Template, RDoc, and Localization
    36 Posts 13 Posters 12.0k Views 13 Watching
      RickW
      This is a template for an "all rights reserved" project. Anyone not wanting to reserve all rights could replace that line with this phrase
      Permission to use, copy, modify, and distribute this software for any purpose and without fee is hereby granted, provided that the above copyright notice appear in all copies.
      or a different phrase of your preference.
      # Supports Organizer.rb
      =begin rdoc
      = ScriptName
      Copyright 2009, Author
      All Rights Reserved
      == Disclaimer
      THIS SOFTWARE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, WITHOUT LIMITATION, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
      == License
      author's license statement
      == Information
      Author;; AuthorName
      Organization;; AuthorAffiliationOrOrganizationIfAny
      Name;; ScriptName
      Version;; ScriptVersion
      SU Version;; MinimumSketchUpVersion
      Date;; Date
      Description;; ScriptDescription
      Usage;; ScriptUsageInstructions
      History;;
      1.000;; YYYY-MM-DD
         * description1
         * description2
      1.001;; YYYY-MM-DD
         * description1
         * description2
      =end
      require "sketchup.rb"
      unless file_loaded?(__FILE__)
         file_loaded(__FILE__)
         UI.add_context_menu_handler do |menu|
            menu.add_item("menuitem") { code } # CREATE A SINGLE MENU ITEM IN CONTEXT MENU
            submenu = menu.add_submenu("submenu") # CREATE A SUBMENU ITEM IN CONTEXT MENU
               submenu.add_item("menuitem1") { code }
               submenu.add_item("menuitem2") { code }
         $submenu ? (organizer = $submenu) ; (organizer = UI.menu("Plugins"))
         organizer.add_item("menuitem") { code } # CREATE A SINGLE MENU ITEM
         submenu = organizer.add_submenu("submenu") # CREATE A SUBMENU ITEM
      Feedback?
      Does anyone really want to use the embedded documentation format?
      Does anyone really want to use the embedded html (=begin html) format?
      Does anyone have an idea for templating the menuitems for language localization?
      EDIT 2009-01-29: added a descriptor for the minimum SketchUp version required (thanks Thomas). The "default" would be '4' since that is when ruby was added to SU.
      EDIT 2011-10-19: changed the above code sample to match the revised code sample from a later post, in hopes of alleviating confusion. For posterity's sake, the original code sample is here:
      =begin
      All Rights Reserved
      License;	author's license statement
      Author;		AuthorName
      Organization;	AuthorAffiliationOrOrganizationIfAny
      Name;		ScriptName
      Version;	ScriptVersion
      SU Version;	MinimumSketchUpVersion
      Date;		Date
      Description;	ScriptDescription
      Usage;		ScriptUsageInstructions
      History;
      	1.000	YYYY-MM-DD
      		description1
      		description2
      	1.001	YYYY-MM-DD
      		description1
      		description2
      =end
      RickW
      www.smustard.com
        Looks good by the first glance.
        I want to have a look into how easy it is to reliably extract plugin data in regards to auto updaters etc. Maybe include an compatible list, a list that states which SU version it's compatible. And optionally, and list of plugins that might be incompatible with?
        What I'd like as alternative for the text is where it's allowed to copy, modify and distribute for non-commercial use. I'm not really sure how it's best phrased these sort of things.
          Matt666
          Good idea Rick!
          Thank you for this suggestion...
          Frenglish at its best !
          My scripts
          • H Offline
            Heven7_floor
            Great and beautiful idea 👍 ! Are there any helping for amateurish codding ? , such event block code suggestion ,as collection of necessary or most usage event
            ex.
               Class *name...
                  def initial
                  def onMouseMove(flags, x, y, view)
                  def onLButtonDown(flags, x, y, view)
                    as the one who expertise codder shall please to new face like me for most usefully event suggestion for SU script codding   :tada:
              @rickw said:
              I'm not an attorney, but this might work:
              Permission to use, copy, modify, and distribute this software for noncommercial purposes and without fee is hereby granted, provided that the above copyright notice appear*s** in all copies. Commercial distribution, in whole or in part, is expressly prohibited without the express**ed,** written consent of the author.*
              Well, I AM a lawyer, too, and I think it's okay.
              I used to be an English teacher, too... 😳
              • Chris FullmerC Offline
                Aren't you a little over-qualified to be goofing around on the forum all the time then? 🤣
                All my Plugins I've written
                • scottliningerS Offline
                  scottlininger
                  Purely my bias, but I'd lean toward the RDoc comment style. Either way, this looks extremely helpful!
                  • Scott Lininger
                    SketchUp Software Engineer
                    Have you visited the Ruby API Docs?
                    @chris fullmer said:
                    ...Aren't you a little over-qualified to be goofing around on the forum all the time then? 🤣
                    Wait till I have the time to finish my PhD thesis! 😄
                      RickW
                      Using RD or RDoc style would be more consistent with the =begin/=end usage (rather than using it for block comments). Something like this?
                      =begin rdoc
                      = ScriptName
                      All Rights Reserved
                      == Disclaimer
                      == License
                      == Information
                      Author;; AuthorName
                      Name;; ScriptName
                      Date;; Date
                      History;;
                       1.000;; YYYY-MM-DD
                         * description1
                         * description2
                       1.001;; YYYY-MM-DD
                         * description1
                         * description2
                      =end
                      RickW
                      www.smustard.com
                        I'm in favour of using an existing method of documentation.
                          scottlininger
                          Exactly. I didn't run this though RDoc to see the output, but my point is that RDoc is the closest thing to a docs standard that I'm aware of. Might as well build something that could be run through RDoc and give sensible output.
                          Now you should extend the template list and build a Ruby plugin wizard! 😉 (only half joking.)
                          • Scott Lininger
                            This is shaping up good. 😄
                            I'm wondering, for the changelog, does the RDoc have a syntax for lists? Just thinking there's something that might denote a list item. I don't find enough space on one line to describe a change some times. I've up til now used a * to indicate list items.
                            Like this:
                            # Changelog
                            # 1.0.0 - 13.12.2008
                            #       * Select Active Instances
                            #       * Select Instances
                            #       * Select Active Group Copies
                            #       * Select Group Copies
                            #       * Convert Group Copies to Instances
                            # 1.1.2 - 16.12.2008
                            #       * Select Loop from edge
                            If the description breaks to another line the * makes it clear when the next item starts.
                            So if there's an RDoc syntax for this I suggest we use that.
                            Also, in addition to SU version, OS Platform is useful as some scripts works only on either Mac or PC.
                            And, I'm wondering if it's worth to include a Webdialog engine, since some plugins fail due to the user having an old IE version installed. (Not sure how it's on OSX. The rendering engine is webkit, right? but does it change if you update Safari?)
                              RickW
                              It should be straightforward, using a regexp to parse the file. The fields are known (that's the point of this exercise), so writing a parser should be easy. The challenge, IMO, is to keep it easily human-readable, while allowing machine readability.
                              Permission to use, copy, modify, and distribute this software for noncommercial purposes and without fee is hereby granted, provided that the above copyright notice appear in all copies. Commercial distribution, in whole or in part, is expressly prohibited without the expressed, written consent of the author.
                              Edited per Gai. I found both "express written" and "expressed written" online, didn't know if one was more correct for legal jargon.
                              RickW
                              www.smustard.com
                                RickW
                                There is a list syntax. See the RDoc docs for more info.
                                RickW
                                www.smustard.com
                                  todd burch
                                  I'm on this like a Hobo on a Bologna sandwich.
                                  Get your requests in now, during the early design stages. We're gonna have a GUI!!!
                                  Stay tuned. Todd
                                    RickW
                                    Developers,
                                    Please note that the menu information is also part of the template, designed to function with Organizer.rb (even though Organizer.rb is NOT required for the menu to work).
                                    If you choose to not use this menu template, please also remove the top line of the header "# Supports Organizer.rb". Otherwise, users trying to use OrganizerEdit to make your work compatible with Organizer will not be able to do so. Then I'll get support requests, and I'll have to forward them on to you to fix the issues 😄
                                    Here is the documentation for creating Organizer-compatible menus (though the work has already been done in this template)
                                    RickW
                                    www.smustard.com
                                      RickW
                                      I'm considering adding this to the ruby template, but wanted to get input. After a rather infamous incident recently, I thought about easing the localization effort for menus, and came up with this:
                                      1. create a "menus" subfolder in the Plugins folder (to keep things tidy)
                                      2. in that folder, create a text file with the same name as your .rb file, with the extension ".menu" and put each menu item text string on a separate line, like this (the submenu, submenu2, etc names are only to illustrate where they are in the menu structure for this particular example):
                                      context menu label
                                      submenu label
                                      submenu item label
                                      submenu2 label
                                      submenu2 item1 label
                                      submenu2 item2 label
                                      submenu2 item3 label
                                      submenu2 item4 label
                                      submenu2 item5 label
                                      submenu2 item6 label
                                      # This file may be translated for localization
                                      1. use the following example code to read the lines from the .menu file into your menu structure:
                                      	menunames = IO.readlines(File.dirname(__FILE__)+"/menus/"+File.basename(__FILE__, ".rb")+".menu").collect{|x| x.chop}
                                      		menu.add_item(menunames[0]) { code }
                                      	submenu = organizer.add_submenu(menunames[1])
                                      		submenu.add_item(menunames[2]) { code }
                                      		submenu2 = submenu.add_submenu(menunames[3])
                                      			submenu2.add_item(menunames[4]) { code }
                                      			submenu2.add_item(menunames[5]) { code }
                                      			submenu2.add_separator
                                      			submenu2.add_item(menunames[6]) { code }
                                      			submenu2.add_item(menunames[7]) { code }
                                      			submenu2.add_item(menunames[8]) { code }
                                      			submenu2.add_item(menunames[9]) { code }
                                      This particular example does everything except submenus and separators for the context menu.
                                      As I see it, this will make localization a breeze, since someone only has to translate the .menu file, which is plain text. It also eliminates copyright problems, since the code is unchanged.
                                      Thoughts?
                                      RickW
                                      www.smustard.com
                                        So use user completely replaces the menu language file?
                                        Just wondering about packaging. What if you want to include multiple language packs? (Or maybe this isn't the scope for this? This is purely a bare minimum way of allowing localization?)
                                          todd burch
                                          I smell a good application for an XML file.
                                            todd burch
                                            Maybe something like this:
                                            <?xml version="1.0" encoding="UTF-8"?>
                                            <menufile>
                                            	<mainmenu name="Tools">
                                            		<item>My Ruby Script V1.0</item>
                                            		<submenu text="First Submenu">
                                            			<item>Function 1</item>
                                            			<item>Function 2</item>
                                            			<sep/>
                                            			<item>Function 3</item>
                                            		</submenu>
                                            		<submenu text="Help">
                                            			<item>Contact Author</item>
                                            			<item>User's Guide</item>
                                            			<item>YouTube Video</item>
                                            		</submenu>
                                            	</mainmenu>
                                            </menufile>
                                            • 1 / 2
