    [REQ] Seamless stone texture...
    10 Posts 6 Posters 1.8k Views 6 Watching
    • B
      bubbalove
      I need a seamless stone texture for a project I am currently working on. It looks like this...Stone Picture.jpg
      I tried to create one but I suck at editing and creating textures... here is my feeble attempt! I tried to rotate, flip, copy, and clone but I can't get it where it needs to be...Stone Texture.jpg
      Here is what it looks like on the building... its tiling pretty bad! Entrance w stone.jpg
      I was hoping one of the texture kings can help me make the one I have better or maybe point me in the right direction... I'm not asking for a handout... just some help! Thanks in advance!
      PS - Yes I searched through the links in the first post... but most of them aren't easy to use. I have a FormFonts account... but the only one that was similar to what I need was sooo small...
      BubbaLove
      "Success consists of going from failure to failure without loss of enthusiasm." - Churchill
      • P
        perk
        Bubbalove
        I have run into this problem before and found the best stone pattern to start with is one native to SU. The reason being is someone has already taken the time to tile it properly which is where the difficulty in a pattern like this lies, as you have found out. I bring that into photoshop and alter it to my desire. Just a little trick I use if that helps you at all.
        • boofredlayB
          boofredlay
          Here is one that might help.
          • B
            bubbalove
            Thanks Perk and Boo... I'll try both of them and see what I can come up with...
            • T
              tomsdesk
              David, try here: http://www.cgtextures.com/
              2.5D Trees & Shrubs!
              • B
                bubbalove
                Tom, that was the second website I went to after FormFonts and I couldn't find anything close to what I was looking for. Maybe I need to spend more time looking...
                • soloS
                  solo
                  Maybe this will work, I use these for rendering, I have the matching bump if you want it.
                  http://www.solos-art.com
                  • B
                    bubbalove
                    Thanks for your help Pete... Ill take the bump if you wanna give it to me...
                    • soloS
                      solo
                      Sure thing.
                      • B
                        bubbalove
                        I tried to make one but like I said earlier I'm not good at making or editing textures but you did an excellent job. Thanks again to everyone that helped... you will see this model in the gallery within the coming days!
