    UI.set_toolbar_visible
    8 Posts 5 Posters 724 Views 5 Watching
    • Chris FullmerC Offline
      Hi, I'm learning, so go easy on me. (I'll probably need to preface every post of mine here the ruby forum forever, or you could just remember that and I'll quit posting it πŸ˜„ )
      So I am playing with the UI.set_toolbar_visible .....method?....... And I have gotten it to work. I can close and open toolbars as I see fit. But there are 4 toolbars that don't seem to be control-able.
      Large Tool Set
      Layers
      Measurements
      Shadows
      So I'll attempt to post my code. 😳
      toolbar_names_counter = 0
      UI.toolbar_names.each do
      	name = UI.toolbar_names[toolbar_names_counter]
      	is_visible = true
      	status = UI.set_toolbar_visible name, is_visible
      	toolbar_names_counter = toolbar_names_counter +1
      So that should go through and turn on every toolbar (I think). But it never opens the four I listed.
      So then I found UI.toolbar_names. I type this into the ruby console:
      puts UI.toolbar_names
      and I get this output:
      Standard
      Principle
      Camera
      Drawing
      Edit
      Construction
      Walk
      DisplayMode
      StandardViews
      Section
      Google
      GettingStarted
      VCB
      Apparently those 4 toolbars are just not listed in the UI.toolbar stuff. Is there a way to access the unlisted toolbars?
      Thanks,
      Chris - sorry such a long post for something probably trivial.
      All my Plugins I've written
        Wonder if they are special elements. Layers, Measurements and Shadows contains custom content, not just toolbar buttons. Might be why. Not sure why Large Tool Set won't list.
        hm... you'd think there's be an toolbars enumerable available...
          Jim
          It could be called a bug, or there may be other reasons the 4 toolbars are not listed using the "toolbar_names" method. Probably the only ones who can answer that are the developers.
            Darn, that's what I was afraid of. I was hoping that I just missed something because I have no clue what I'm doing. There goes my dreams for a new toolbar manager ruby πŸ˜„
            Chris
            • scottliningerS Offline
              scottlininger
              Hey guys,
              I've filed a bug. If any old-timers remember seeing this one from the years of yore, please let me know.
              Thanks, Chris!
              Cheers,
              • Scott Lininger
                SketchUp Software Engineer
                Have you visited the Ruby API Docs?
                todd burch
                I think I've seen it. I believe there is also still a Mac-specific bug related to this, where the first 4 characters of the toolbar names are truncated.
                  Is there a way that I could write a script that controls the visibility other people's toolbars? Umm, for example, is there a method that will return ALL loaded toolbars, not just the default listed ones, but ALL that have been loaded by other rubies? Thanks,
                  Chris
                    404 Not Found
                    (forums.sketchucation.com)
                    Just linking various related threads together for other people looking for the same topic.
