    Window Placement?
    3 Posts 3 Posters 384 Views 3 Watching
    • R
      retoy1
      Architects chime in here please. In an 8' ceiling residence, how far down from the ceiling should the windows be? (I'm an Electrician!!)
      • honoluludesktopH
        honoluludesktop
        There is often no set height for a window, however the height of a window often matches that of the typical door leading into the room. Some other functional, or aesthetic reason might easily dictate another height. Why do you ask?
        • D
          drewpoeppel
          In a typical residence the doors are 6'8" high. The window tops usually match that, unless the window type or architecture drive it elsewhere.
