    Regex selection filter?
    3 Posts 2 Posters 483 Views 2 Watching
    • thomthomT
      Does any plugin exist which allows you to select group/components by their Group/Definition Name and/or name using a regex pattern?
      • A
        azuby
        Don't know, but wouldn't be a difficult thing:
        # get the input
        r = Regexp.new input
        # iterate over the elements
        #   checking name
        #   adding to selection, if name fits
        azuby
        • thomthomT
          Yea, it'd be a simple loop. Just wasn't sure if there was a plugin out there already.
          If not I'll add one to my selection plugin.
          Found the use for it today when I imported a revit model using the DWG format. There's no material applied so I have to add that manually. But I noticed that similar element had the same name prefix followed by a number. So I figured I could greatly speed up the process of adding materials by doing a regex selection.
