    Odd Ruby Error
    6 Posts 3 Posters 664 Views 3 Watching
    • thomthomT
      I just noticed an error in the Ruby Console when I right click the model axis.
      Error; #<LocalJumpError; return from proc-closure>
      (eval);1075;in `call'
      Ahyone got an idea of what that might be?
      • A
        azuby
        A return statement from a do..end / { } block is used in one of your installed Ruby scripts.
        azuby
        • thomthomT
          The keyword 'return' being used in a do block?
          • A
            azuby
            That should be the reason.
            azuby
            • thomthomT
              ok. thanks. then I know what to look for. amongst all the plugins installed... ...just hope it isn't a scrambled plugin that's the culprit.
              • T
                todd burch
                Since you are getting it when right clicking on a axis, then the failing code is most assuredly a proc for displaying a right click context menu for a script. You can narrow your search down to any scripts you have that generate context menu selections.
