    My second rendering...
    5 Posts 4 Posters 707 Views 4 Watching
    • F
      fymoro
      This rendering takes me all the day to make the scene (column & trompet from sketchup web component)
      The most long for me beginner was to parameter the bump map, the light etc...
      I think that I start to be crazy for Sketchup and Vray.... 😎
      I wait your comments, Bye.
      direct from rendering, 20 minutes
      http://www.thearender.com/cms/index.php/news/featured-artists/137-frederic-yves-moro.html
      • MALAISEM
        MALAISE
        Hi Fymoro
        You're learning very fast. I'm not really the right one to comment this impressive Vray picture.
        May be you could improve the tiles positionning ( far left ).
        Friendly
        MALAISE 👍
        • J
          juanjo06
          MEN this is so nice. very good muy bueno felicidades! 👍 👍 👍
          the gold material really defined.
          • F
            fymoro
            Thanks,
            I will make some changes.
            The gold material is the "gold_shiny.vismat" in the Vray material editor.
            I think that for make a nice picture the position and The field of the view of the camera is very important. I put at 50'.
            I take my time, I follow tutorial and many discussion issue from this forum and It is very helpful... ☀
            Thanks for your comment.
            Fymoro
            • P
              perk
              fymoro
              I Think you have done a great job on this image, very realistic looking.
              I do agree that the tile on the far side need to be aligned and after hearing that comment I noticed that the tile on the near side is (slightly) misaligned as well. I agree that changing the field of view is an important thing but in this image the first thing I noticed is that the field of view is off a bit. To me, it looks as if the columns are leaning outward. I usually use a setting of 35. One last comment is that the trumpet appears to be floating just a bit. I think it would actually rest on three points, (for lack of better terms since I know nothing about musical instraments) I think the mouth piece would rest on the ground as well.
              Other then that, GREAT work!!
