    My first rendering
    7 Posts 4 Posters 830 Views 4 Watching
    • F Offline
      fymoro
      Hi all, happy new year,
      I am new in this forum and I practice Sketchup since 5 month.
      This is my first rendering Sketchup Vray, I need your comment and help...
      The scene is very simple, but I have working 3 hours on the textures and lightings
      The Spotlight are very difficult to make (3hours with the omni light parameter) 😲
      This Picture is directly with vray no photoshoped... 35 minutes rendering time.
      Thanks for your reply. 😎
      http://www.thearender.com/cms/index.php/news/featured-artists/137-frederic-yves-moro.html
        Hi Fred and welcome to GSCF.
        To tell the truth,I am not a rendering guru so you cannot expect too much constructivecriticism from me but I still have a question; is it correct that to me the bookshelves seem to emit light? It would be quite strange.
        Otherwise I like the render (and agree that spotlights are hard to control)
        • F Offline
          fymoro
          Hi Gaieus,
          Thanks for your comment, yes the book shelves are lighty, but it was a try to render emissive effect.
          In fact what is difficult with the 3d in general it is the ideas.... 😎
            Okay, I see now - testing...
            I'm not sure about Vray but many many emissive surfaces generally boost rendering time so also keep that in mind.
            • H Offline
              HFM
              Look pretty impressive. And, if you compare it to my first 'render' it is godlike 😄
              The next step you could take is adding a bump map to the floor, which will make it look far more realistic
              • F Offline
                fymoro
                Thanks HFM,
                Yes you are right, I will add a bump map to the floor.. 😎
                • MALAISEM Offline
                  MALAISE
                  Hi Fred
                  I rode what Gaius has written and I agree too. May be you may also focus on books which seem to be copies of the same group. You could rotate them.
                  Quite impressive work 👍
                  MALAISE
