    GTAInside Help
    15 Posts 9 Posters 1.6k Views 9 Watching
    • K Offline
      KDSDESIGN
      Well i have 6 or so files from GTAinside, (DFF Files) How do i get the into SketchUp?
      Regards,
      █Kevin█
      (about 20% done)
      • P Offline
        pav_3j
        after a few minutes deciphering your cryptic post (you at no point describe the problem, or what GTAinside is, or what you have done so far yourself to try and fix your problem)
        i came across this, which is hopefully useful for you.
        i thought it would be a big problem finding information on this, as i assumed (first mistake) that you had done some research yourself.
        i found however that just by punching in "dff" and "sketchup" into google the first result it yielded had the answer.
        i do feel like i have wasted my time slightly, but never the less i hope you find it helpful.
        Pav
        Just won the 'Who is Least Competitive Championships' where trying to win will make you lose. Trying to lose makes you win which makes you lose. Not trying at all makes you lose which makes you win which makes you lose.
        • soloS Offline
          solo
          .DFF is a Grand theft auto export extension, I am not 100% sure but I believe 3Dmax 8 and up can open it and export from there to .3ds which can be used in SU.
          http://www.solos-art.com
          • P Offline
            pav_3j
            Spot on solo, as always!
            The link I put forward does suggest though that if you wish to put it back into gta, it isn't a good idea as the model holds "hierarchy" and "axis" information necessary for gta to use it (i have no idea what that means)
            By converting to .3ds and then importing to sketchup, you lose this information and the model becomes a "useless object", which cannot be used in gta.
            Of course if this isn't the objective, solo's method is the way to go KD.
            Pav
              remus
              Theres a list of progrms tat can import/export .dff here: http://www.gtamodding.com/index.php?title=Model_file
              Blender would probably be your best bet, being free and having a wide variety of import/export options.
              • K Offline
                KDSDESIGN
                i clicked on this one "3DSMax/Gmax import/export" and it sent me to a topic. where do i get this?
                NO THIS IS NOT AN OFFER JUST IN CASE IT SOUNDS LIKE ONE. and sorry about the "yelling"
                Regards,
                █Kevin█
                (about 20% done)
                • K Offline
                  KDSDESIGN
                  it didnt work. ❓
                  Regards,
                  █Kevin█
                  (about 20% done)
                    remus
                    The topic the link links to a plugin for working with .dff files in 3ds max and gmax. 3ds max is a rather pricey piece of modelling/animtion/rendering software, although i think you can get a student license for it. Google should have some more details for you.
                    If i remember gmax is a free version of 3ds max with a lot of the tools removed. I dont think its being developed any more, though, so you might be better of looking in to some of the alternative packages first.
                    • K Offline
                      KDSDESIGN
                      does gmax import into SketchUp?
                      Regards,
                      █Kevin█
                      (about 20% done)
                        remus
                        Not directly, if at all.
                        ive done a brief bit of reading about it and it seems gmax was limited to certain 'game packs'. I also found no mention of any export options, which makes me think youd have to export to a format supported by one of the game packs which can be imported in to something else (perhaps blender) and then in to SU.
                          Bryden
                          I have actualy worked out a combination using Blender and 3d object converter 4.20
                          First download the converter http://web.axelero.hu/karpo/
                          "It doesn't need to be registered"
                          If you don't have Blender get it here: http://www.blender.org/
                          After installing the converter launch it then go to file > open pick the .dff file you are going to convert then once it loads go to save > PLY Binary (.ply).
                          Then after saving it open Blender delete the cube then go to
                          file > import > Stanford PLY (
                          .ply). Find the file you just converted before then it should import properly then go to file > export > 3d Studio (*.3ds) or DXF. Then after saving it open sketchup and import the .3ds or .dxf file.
                          "Important Note: Not all dff files will import to the converter I don't know why."
                          I hope that helps it worked for me 😄
                            johnsenior1973
                            @kdsdesign said:
                            Thank you everyone for all the help. It's really appreciated.
                              linea
                              Hi KDS, everybody
                              I have GMAX, I believe the story there is that when AutoDesk bought 3DS Max from Kinetix some of the source code was open source so Kinetix released GMAX as an open source freebie. I think I got it on a computers arts mag coverdisc in er, 1996 maybe. If you really trawl the net you will find forums and die-hard game modders that still use it and write exporters for it - it doesn't come with any (or any materials) so out of the box it isn't particularly useful. The interface is exactly the same as older versions of 3DS.
                              You can download GMax here:
                              http://www.turbosquid.com/gmax
                              Milkshape and Real 3d have loads of game exporter formats. Links to the free versions.
                              http://cad-3d.blogspot.com/2007/04/gratis-versie-van-realsoft-3d.html
                              http://www.toggle.com/lv/group/view/kl36143/MilkShape_3D.htm
                                andyc
                                Just to reinforce the above - GMAX was a bit of dead-end. It was bundled with a number of games titles, but TBH was pretty limited (I know - I tried it for a little while). Plus the fact that MAX's learning curve is probably a little steep for the casual modder. The Blender advice sounds spot-on to me - I've seem some awesome results from this free app, and it seems to handle an impressive range of file types. If you can find your way around the unusual interface, it seems to be very capable. It's on my list of things-to-try in 2009 😉
                                A.
                                • 3 Offline
                                  3eighty
                                  Zmodeler is the program you want..It has the converter for the files..I use it all the time.. 👍
