    Calling Whaat and Fredo!! new MAC issues (SOLVED)
    94 Posts 19 Posters 25.2k Views 19 Watching
    • O Offline
      otb designworks
      HI guys.
      I recently, 3 days ago, upgraded from OS 10.5.5 to 10.5.6.
      Since that time I am experiencing the following issues with your scripts, both of which have been flawless and indispensable since forever ago.
      Wit Bezier Splines, I have lost the existence of a large portion of the toolset, both in the toolbar and in the DRAW menu. I am attaching two screenshots the show what I am now seeing (1 and 2).
      With Subdivide, I still have all functionality of the script, but the tool icons no longer display in their toolbar. When hovering over the buttons, though, I am still receiving the tool name popups, and the buttons still work ( see screenshot 3).
      I have completely reset my hard drive, shut down, trashed plists, trashed the files and deinstalled new downloads ( and confirmed that all the necessary files are there (all the Bezier Spline tools are in their folder, they just aren't showing up in SU), and tried turning extensions off and then on while restarting SU, all to no avail.
      For both scripts, these issues are identical in Ver 6 and Ver 7, which leads me to believe that something peculiar occurred from 10.5.5 to 10.5.6.
      Any other 10.5.6 users able to confirm?
      Thanks in advance.
      Cheers, Chuck
      OTB Designworks is on Youtube
      • BurkhardB Offline
        Burkhard
        Can't confirm, but thanks for warning πŸ˜‰
        http://www.ia-plus.de
        • EdsonE Offline
          Edson
          chuck,
          i confirm that. the same is happening to me and not only with these scripts. several others are behaving like this. perhaps one should contact by pm the scripts' authors.
          regards.
          http://www.mahfuz.arq.br
          • fredo6F Offline
            fredo6
            Kanonbal,
            Very difficult to diagnose, as I don't have any Mac, and furthermore, am not familiar with the subtle differences between the Mac OS X versions you struggle with.
            What I can suggest however is that you do the following procedure:
            1. First deactivate the BezierSpline extension in Windows>Preferences>Extension
            2. Exit Sketchup
            3. Start Sketchup (you should not see any Bezierspline icons)
            4. Turn on the Ruby Console
            5. Go to Windows>Preferences>Extension and activate Bezierspline extension
            6. Watch out potential error messages in the Ruby console. If so, please post the extract.
            By the way, did you have any similar issue with my other scripts (joint push pull, Tools on Surface)?
            Fredo
            • EdsonE Offline
              Edson
              fredo,
              there is no bezierspline extension to be deactivated there. i started the script with the console open but there was no error message.
              there is no problem with the icons for your other scripts, just the bezierspline one.
              • O Offline
                otb designworks
                good morning everyone.
                Edson, I have do have a Bezier curves extension to turn on and off in preferences.
                Fredo, after doing as you suggested, I received the following in the Ruby console:
                /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/BZ_Dir_12/bezierspline_main.rb:472: warning: don't put space before argument parentheses
                /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/BZ_Dir_12/bezierspline_main.rb:539: warning: don't put space before argument parentheses
                /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/BZ_Dir_12/bezierspline_main.rb:576: warning: don't put space before argument parentheses
                /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/BZ_Dir_12/bezierspline_main.rb:576: warning: parenthesize argument(s) for future version
                /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/BZ_Dir_12/bezierspline_main.rb:631: warning: don't put space before argument parentheses
                /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/BZ_Dir_12/bezierspline_main.rb:795: warning: don't put space before argument parentheses
                /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/BZ_Dir_12/bezierspline_main.rb:1044: warning: don't put space before argument parentheses
                /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/BZ_Dir_12/bezierspline_main.rb:1408: warning: don't put space before argument parentheses
                /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/BZ_Dir_12/bezierspline_main.rb:1408: warning: parenthesize argument(s) for future version
                /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/BZ_Dir_12/bezierspline_main.rb:1445: warning: don't put space before argument parentheses
                /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/BZ_Dir_12/bezierspline_main.rb:1445: warning: parenthesize argument(s) for future version
                /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/BZ_Dir_12/bezierspline_main.rb:1555: warning: don't put space before argument parentheses
                /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/BZ_Dir_12/bezierspline_main.rb:2085: warning: don't put space before argument parentheses
                /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/libtraductor.rb:59: warning: don't put space before argument parentheses
                /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/libtraductor.rb:24: warning: already initialized constant PC_OR_MAC
                /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/libtraductor.rb:25: warning: already initialized constant LBT__DEF
                /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/libtraductor.rb:32: warning: already initialized constant VALID_ERROR
                /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/libtraductor.rb:33: warning: already initialized constant VALID_MIN
                /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/libtraductor.rb:34: warning: already initialized constant VALID_MAX
                /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/libtraductor.rb:35: warning: already initialized constant VALID_PATTERN
                /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/libtraductor.rb:174: warning: redefining constant Struct::DlgItem
                /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/libtraductor.rb:174: warning: already initialized constant DlgItem
                undefined method bz_ask_extras for BZ__BezierClassic in file bezierspline_main.rb
                undefined method bz_ask_extras for BZ__Polyline in file bezierspline_main.rb
                Cheers, Chuck
                • O Offline
                  otb designworks
                  I tried the same procedure with Subdivide/smooth and there was nothing in the Ruby Console after turning on the extension.
                  Fredo, as Edson said, I am having no issues with your other scripts (JPP and TOS).
                  Thanks !
                  Cheers, Chuck
                  • O Offline
                    otb designworks
                    After further experimenting by Edson, we have found that the following scripts are also not showing their images in the toolbar buttons.
                    3D Shape Tool
                    Bool Tool
                    frontface
                    polarline
                    So far, Bezier Shapes is the only one that is losing functionality and is also the only one that shows info in the Ruby Console when turning it's extension on.
                    Cheers, Chuck
                      Hi Guys,though I am not a scripter,what we were suggested by the SU dev. team was to disable dynamic components first (in the Preferences > Extensions) and try to see if this helps.
                      Could you also try these things out until Dale or Fredo comes back?
                      What I know is that BoolTools had been tested on the Mac before the release as well and apparently not every Mac user is affected.
                      • O Offline
                        otb designworks
                        Disabling Dynamic Components has no effect on the issues I am experiencing.
                        Again, all this started after upgrading from OS 10.5.5 to OS 10.5.6.
                        Everything worked perfectly in 10.5.5
                        And, these issues are in both SU6 and SU7, so something, somewhere, has gotten screwy in the new OS 10.5.6
                        Cheers, Chuck
                          ScottPara
                          Oddly enough I have updated and I am not having any issue with bool tools or subdivsmooth. The other I am not sure as do not have them loaded.
                          Scott
                          Love the fact that some HATE my avatar.....
                          • O Offline
                            otb designworks
                            well, that's weird.
                            Cheers, Chuck
                              ScottPara
                              I thought so too chuck. Let me know if you need me to look at anything particular.
                              Scott
                              • O Offline
                                otb designworks
                                Hey Scott, here is my question.
                                Bezier Spline is the only plugin, so far, that is actually dropping functions now, as opposed to just losing the images in the toolbar buttons.
                                Any chance you would be willing to download and install it and see what is happening on your system?
                                You can find it here: BezierSplines
                                I eagerly await your results, and secretly hope it doesn't work for you either so at least we have some consistency across platforms.
                                Thanks.
                                Cheers, Chuck
                                • fredo6F Offline
                                  fredo6
                                  I have no clue of what is happening between the different versions of Mac system.
                                  I assume you all use version 1.2 (i.e. script with a sub folder BZ_Dir_12).
                                  The loss of functionality is simply due to the fact that curves are loaded from files BZ__*.rb normally located in the subfolder BZ_Dir_12 (except Classic Bezier and Polyline, which are in the main file). For whatever reasons, the script fails at finding or loading these files.
                                  In order to progress, could you type in the Ruby console the following command:
                                  Bezierspline::BZ___SearchDir
                                  It should precisely display the BZ__*.rb files which have to be loaded.
                                  If not, then there is a problem, probably related to the file system on Mac and how it is called from SU.
                                  Thanks and happy new year
                                  Fredo
                                  PS: I am currently in a place where Internet access is not easy. So I apologize for delays in my answers.
                                  • O Offline
                                    otb designworks
                                    Hi Fredo, thanks for keeping up with this.
                                    I typed as you suggested in the Ruby Console.
                                    All I got was [].
                                    I tried three times and am attaching the resulting screenshot.
                                    Thanks again, and please, for sure there are no apologizes necessary.
                                    Merry Happy,
                                    Cheers, Chuck
                                      ScottPara
                                      Chuck,
                                      Sorry but I will not be able to test it until I get back to work on the 5th 😞 but will do so first thing.
                                      Scott
                                      • O Offline
                                        otb designworks
                                        thanks Scott.
                                        This would only be a very minor inconvenience, except I use the whee out of the Uniform B-Spline, and I miss it very much.
                                        Cheers, Chuck
                                        • fredo6F Offline
                                          fredo6
                                          All I got was [].
                                          Merry Happy,
                                          Then, this is where the problem comes from. I don't now what has happened between the version of MacOS X however, which makes it not working any longer.
                                          By the way, I assume you do have a folder BZ_Dir_12 in your Sketchup Plugins directory, and in this directory, you also have some ruby files like BZ__BSplineU.rb, BZ__Catmull.rb, etc...
                                          Let's take things in order then. In the Ruby console, can you type the following commands (which are actually coded at lines 394-397 of bezierspline_main.rb):
                                          1. sudir = Sketchup.find_support_file "Plugins"
                                            This should give the Sketchup Plugins Directory
                                          2. bzfiles = File.join sudir, "BZ_Dir_12", "BZ__*.rb"
                                            This should give you the path to the ruby files, so, normally
                                            /Library/Application Support/Google SketchUp7/SketchUp/Plugins/BZ_Dir_12/BZ__*.rb
                                          3. lf = Dir[bzfiles]
                                            This should give a list of ruby files BZ__*.rb containing the additional curves.
                                          Something goes wrong between step 1 and step 3.
                                          Fred
                                          • O Offline
                                            otb designworks
                                            Hi Fredo, good morning.
                                            I am enclosing 4 screen shots.
                                            The first is my plugins folder, with all the Bezier Spline plugins and folder structure visible.
                                            The next three are the results of the three commands you wanted me to type into the Console.
                                            Obviously, something isn't working with number three, as all I get is: []
                                            Thanks!
                                            Cheers, Chuck
                                            • 1 / 5
