    🤑 SketchPlus 1.3 | 44 Tools for $15 until June 20th Buy Now
    ZWCad 2008i
    7 Posts 5 Posters 1.3k Views 5 Watching
      mdlok
      Hello all,
      Not sure if this is the right place, but:
      I came across a nice substitute for Autodesks Autocad.
      It's called ZW Cad 2008i and is made in China.
      You can download (http://www.zwcad.org/index.html)a trial version here for 30 days, after that some items become limited.
      It claims to be compatible at least with Autocad 2007 (after 30 days of evaluating).
      The price is also a lot cheaper than Autocad.
      It looks about 95% the same as Autocad. So for those that are used to work with Autocad, there is no problem at all. Actually you would think it is Autocad, but with another skin.....
      And no, I'm not receiving any commission........
        Matt666
        Hi !
        How much after 30 days? 😄
        Frenglish at its best !
        My scripts
          linea
          ZW CAD is a chinese distribution of ProgeCAD (formerly called Intellicad). Try ProgeCAD Smart, its free, the full version is around £100
            mdlok
            @matt666 said:
            Hi !
            Hi Matt666,
            In Holland (and so probably also in France) ZWCad2008i Pro would cost around € 525,- (excl. VAT)
            I've discovered that in the evaluation version (after 30 days) you can't save files bigger than 800kB. 👎
            Merry Christmas,
            mdlok
              rogerra
              Will the program open and work with existing Autocad drawings?
                mdlok
                Yep,
                As far as I've tried there is no problem at all using Autocad drawings. Even Autocad drawings with extensions such as Delta Pi are functioning normally!
                • G Offline
                  Graham
                  ZWCAD 2009 is now released and it's fully compatible with acad (full, not just LT), up to dwg 2009. It comes in 2 flavours Std @ £390 and Pro £480 (UK prices). Pro has 2d & 3d design support, Std just has 2d design, but can view 3d files. If you know acad you can use zwcad, no retraining required. Get a free download from http://www.zwcad.org.uk.
