    Correct plugin
    3 Posts 2 Posters 1.1k Views 2 Watching
      tomislavm
      I hawe downloaded 3 diferent versions of sketchyphysics but any is not working correctly.
      Is there correct one with good tutorial?
      Thank You!
      • P Offline
        Platypus5
        You must download the original sketchyphysics first. After following the instructions, check to see that the first sp works. Then, go to sketchyphysics 2 download and click...i forget which one. This one will have an installer. Run it, and check if everythign works. If they don't work, don't panic. It takes several tries. Fiddle with the file paths, perhaps....
          tomislavm
          Thank You but where the .... is original sketchyphysics to download!
