    Tapers
    4 Posts 3 Posters 609 Views 3 Watching
      Jim57
      Pardon the dross-posting to Features Requests, as I'm not sure where this properly belongs.
      I'd like to see an extension of the scaling mechanism.
      Simple objects are no problem, I can select part of them and scale it and the rest follows. Complex objects can't be tapered this way.
      Could there be another modifier key to use with Scale? We use Option/Alt to scale about center and Shift to toggle Uniform Scale. Maybe Command to scale just an end or side of the object?
      I think of this working by scaling across the side of the grid of scaling handles, rather than through the center as Scale works now. I've made a simple file that shows what I mean.
      Taper Illustration.skp
      • rodrigonotorR Offline
        rodrigonotor
        Is place http://www.drawmetal.com they describes as:
        DrawMetal™ provides plugins (extensions) for SketchUp® for drawing curved tapered shapes common in architectural and ornamental metalwork and for calculating the amount of stock required to fabricate the tapers.
        and have a Taper Maker, http://www.drawmetal.com/tapermaker, maybe this help you
        Regards
        • [Sketchando.net](http://foro.sketchando.net/portal.php) • www.arqcad.net •
          That's a very cool script indeed! What a time saver! And with rather complex geometry, too!
            rodrigonotor
            Yes, Gaieus, is very cool, I wish I could use it as soon as possible, but I don't have a project to work in it.
            best regards
