    ⌛ Sale Ending | 30% Off Profile Builder 4 ends 30th September
    Changing scenes from Ruby
    5 Posts 3 Posters 610 Views 3 Watching
      Dhruv
      **What I am trying to do,
      I am trying to change scenes through web-dialogue, Inside web dialogue I have buttons upon which clicken on , scenes will change.
      Here is part of my ruby code.**
      @@xzybit_dlg.add_action_callback("get_data") do |web_dialog,action_name|
      if action_name=="selected_page"
      #For scene 1
      pages = Sketchup.active_model.pages
      pages.selected_page = pages["Scene 1"]
      #js_command = "passFromRubyToJavascript("+ selected_page.to_s + ")"
      web_dialog.execute_script(js_command)
            # For scene 2
            if action_name="selected_page"
                pages1 = Sketchup.active_model.pages
                pages1.selected_page = pages1["Scene 2"]
            # For scene 3 , bug for now, it goes to scene 2 when clicked upon scene 3
                pages2 = Sketchup.active_model.pages
                pages2.selected_page = pages2["Scene 3"]
      Here is part of my javascript code
      function callRuby(actionName) {
      query = 'skp:get_data@' + actionName;
      window.location.href = query;
      <input type="button" onclick="callRuby('selected_page')">
      <input type="button" onclick="callRuby('pages1.selected_page')">
      <input type="button" onclick="callRuby('pages2.selected_page')" value="Scene 3">
      scene 1 and 2 are working fine. But when I click on Scene 3 it goes to scene 2 and not scene 3, which needs to be fixed.
      Thank you,
      Dhruv
        Dhruv
        Here is the corrected part of javascript. But still I am facing the same problem. Actually that was a typo in my previous post.
        <input type="button" onclick="callRuby('selected_page') value ="Scene1">
        <input type="button" onclick="callRuby('pages1.selected_page') value = "Scene2">
          Jim
          Dhruv,
          Add some 'puts debugging' in your callback to see what strings are being passed by the Javascript:
          ???.add_action_callback("get_data") do |web_dialog,action_name|
          puts "action_name=#{action_name}"
            RickW
            First off, action_name will only equal "selected_page" for the first button. The second button will return "pages1.selected_page" for action_name, and the third button will return "pages2.selected_page", so the equality check needs help. Second, there's probably an easier way to accomplish things.
            The general form for callbacks is
            add_action_callback(callback_name) {|dialog,parameters| action}
            callback_name is the name of the callback. In your case, a good callback name might be "show_scene".
            dialog will return the active dialog object.
            parameters will return any parameters you send, and can be used just like the GET method for submitting forms. Of course, you could send a simple parameter like "scene1".
            action should ideally call a method in your class, rather than trying to handle everything right there, unless it's a really short action.
            @@xzybit_dlg.add_action_callback("select_page") {|web_dialog,page| show_page(page)}
            def show_page(page)
                pages.selected_page = pages[page]
            #javascript
            function showPage(page) {
            query = 'skp;show_page@' + page;
            #html
            <input type="button" onclick="showPage('Scene1') value = "Scene1">
            <input type="button" onclick="showPage('Scene2') value = "Scene2">
            <input type="button" onclick="showPage('Scene3') value = "Scene3">
            Now, you may be trying to accomplish other things besides just activating a scene. Just add more callbacks and methods. It's often easier than trying to create a do-everything callback, unless the actions are very similar.
            RickW
            [www.smustard.com](http://www.smustard.com)
              Dhruv
              Thanks Rick and Jim 😄 that helped!
