    Checkbox Menu item
    6 Posts 2 Posters 658 Views 2 Watching
    • thomthomT
      Is it possible to create an menu item which you can toggle on/off. A checkbox menu item? Like the Hidden Geometry menu item under the View menu?
      • J
        Jim
        Sure can, Thomas. This contrived example works. Just change the global $f to true in the Ruby Console to see the checkmark in the menu.
        $f = false
        def hi
          puts "hi"
        menu = UI.menu("Plugins")
        item = menu.add_item("Hi") { hi() }
        def vp
          return MF_CHECKED if $f == true
          return MF_UNCHECKED if $f == false
        menu.set_validation_proc(item) { vp }
        • thomthomT
          Great! Thanks! πŸ‘
          • thomthomT
            btw, where did you find them constants?
            • J
              Jim
              in UI::Command, where else? πŸ˜†
              Your procedure should return either MF_ENABLED, MF_DISABLED, MF_CHECKED, MF_UNCHECKED, or MF_GRAYED.
              • thomthomT
                I see. I never looked that that class yet. I just saw the UI::Menu class and thought that was the one. And there was nothing on the constants there.
                It says that UI.Command is the preferred way to add toolbars and menu items, but why? what's the difference and benefit?
