    Back slashes in read_default
    5 Posts 2 Posters 522 Views 2 Watching
    • Al HartA Offline
      Al Hart
      Wow,
      I was really surprised that this code failed so badly
      (responses from the ruby console are indented)
      splant_file = "c;\\tmp\\test1.ArPlant"
          c;\tmp\test1.ArPlant
      Sketchup.write_default("RpTreeMaker","test",splant_file)
          "c;\tmp\test1.ArPlant"
      Sketchup.read_default("RpTreeMaker","test","")
          c;	mp	est1.ArPlant
      The backslashes followed by T got converted to tabs after being processed by write_default and then read_default.
      Al Hart
      http://wiki.renderplus.com/images/e/ef/Render_plus_colored30x30).PNG
      IRender nXt from Render Plus
        Jim
        Hi Al,
        I just did some experiments and found that the / works just fine as a file path separator on both windows (and I assume macs.) It might save you some headaches.
        • Al HartA Offline
          Al Hart
          Thanks,
          The file name though came from an OpenFile dialog (which returns back slashes), and would be passed to one later (which requires back slashes).
          So I had to convert the code to look like this:
          slast = Sketchup.read_default("RpTreeMaker", "slast_plant_file", "")
          slast = slast.tr!("/", "\")
          splant_file = file_save_dialog( "ArPlant file", "ArPlant Files (*.ArPlant)\0", "ArPlant", slast )
          return if !splant_file
          we cannot write \ to SkecthUp defaults
          splant_file.tr!("\","/")
          Sketchup.write_default("RpTreeMaker", "slast_plant_file", splant_file)
          Al Hart
            Jim
            I think that's a common idiom when dealing with file paths in plugins, although I use
            "path\\to\\file.ext".gsub!(/\\/, '/')
            I did try openpanel and savepanel, and both appear to work using the / character, so you'd only need to translate on the initial path retrieval.
            You can write \ to the the sketchup defaults, but you need to escape the 's
            file = "c;\\\\tmp\\\\test1.ArPlant"]
            Sketchup.write_defaults "Lib", "Key", file
            • Al HartA Offline
              Al Hart
              Thanks for helping look into this Jim.
              GetSaveFile probably accepts the / as well. (I didn't test it).
              I have always been a little disappointed in UI.openpanel.
              Using Win32API.so (which requires that you install a second file with your plugin and only works with Windows Apps), lets me specify patterns for acceptable extensions, and also to specify a default extension to be appended if the user doesn't enter one.
              And the GetOpenFile version lets me require that the file exist before the use can hit OK.
              Small things. But it is too bad that SketchUp can't find the time to update some of their routines. (This could easily be done with either new routines, or optional parameters, to make them a little more useful.)
              However, the main point of the original post is that it would be nice if you could pass write_default() a string and have it save it and return it, without having to "reverse engineer" which characters don't work.
              Al Hart
