    [REQ] POLY SIMPLIFIER
    3 Posts 2 Posters 1.2k Views 2 Watching
    • S
      silver_shadow
      Hi guys..i just want to know...
      is there a possibility to create a rubie to reduce poly count on an object, but you can set it...like if you draw a circle, you can make it 12 segments..but afterwards make it lower. Also there is a rubie that makes high poly contours less (simplify contours)
      so this is the request...
      Say you build something... organic i suppose, and afterwards you realise its 4 mb big.. but you only want 1mb, so instead of rebuilding the model...to use this plugin, where it checks like the simplify contours, closest faces and merge them to make it a lower poly model.
      I would really really really want this
      • J
        johnsenior1973
        Whaat released a polyreducer plugin:
        http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=9789
        • S
          silver_shadow
          my bad..thanx πŸ˜„
