SectionCutFace.rb
Hello...does anyone know why I am having a problem getting the SectionFaceCut.rb to work with Sketchup Pro 7? It works great with Sketchup Pro 6!!
Any help is appreciated....
Works good also in V7. I didn't have any trouble jet!
Welcome Max,
Many times when a script fails, clues can be found in the Ruby Console window (in the Window menu.) You need to open the Ruby Console first, then try to use the plugin. If any errors appear, then cut & paste them here, or take a screenshot.
I had the same problem with this script in version 7. I downloaded the latest version and it worked. Try that.
Best
