    Divide Curves
    13 Posts 5 Posters 3.6k Views 5 Watching
    • CadFatherC Offline
      CadFather
      if there was a scripts that worked like the rightclick divide (or Didier's divide line) to split curves into equal parts, i would gladly pay for the script
      i think we need it badly! πŸŽ‰ πŸ˜„
        I could imagine problems with such a script - if you don't divide a curve as many parts as its segments, you may end up with an uneven series of parts.
        Of course, with "regular" shapes like circles and half circle arcs an obvious solution could be to just draw the circle/arc with the desired segments and then explode it but I guess this is not what you want.
          CadFather
          you're right Gaeius - that is why i need all the master brains i can get
          perhaps it is 'impossible' πŸ˜•
          i've got an idea but am at work................. πŸ˜’
            How about a script instead, which would estimate the "curviness" of any curve and redraw it with segments of equal length? Something like how Didier's ellipse ruby draws the ellipses (although I doubt that it uses a scaled circle as a starting shape).
              CadFather
              telepathy anyone? πŸ˜†
                Well, I have ideas and I somehow can already "guess" (maybe by experience) how a scripter may approach a problem but of course I am no way able to make a script myself. πŸ˜„
                Anyway, It could be some kind of reversed polyline approach?
                  CadFather
                  yes, if i could only write scripts (would probably not set foot out of the house)
                  in one idea, the script recognises a 'curve' (curve, arc, polygon (+ polyline, bezier?)) - then finds the 'form' so that this can be recreated according to the divide value. of course this spells potential trouble for 3d shapes
                  another idea i increasingly like is to just split the curve but not changing its segmentation (basically into smaller curves) - really this is Didier's divide script adapted, you would get c-points where the new cuts have been done
                  even with this dodge approach i can think of many ways to use it - (copy along path for one)
                    Yeah, or camera paths...
                      CadFather
                      Didieeeeeeeeeeer! πŸŽ‰ πŸ˜†
                        Use the curve tools (Classic Bezier curve, Polyline, Uniform Bezier curve, Catmul Spline, Polyline etc)... by Fredo6
                        and Right Click / Convert to Polyline divider or Segmentor (Where you can input any equal interval you want) β˜€ !
                        Et voilΓ ! πŸ˜‰
                        PS And I believe the more funny is that you who have made the drawing of icons πŸ˜‰
                        Based on the sequence of control points and an Interval value, this
                        extension generates a Polyline where all segments have the same length
                        (except the last one). All points of the curves are on the original polygon of
                        control points. This may be used to simplify curves or balance the space
                        between points.
                        So make your curve with one more segment and you will obtain that you want πŸ˜„
                        • Didier BurD Offline
                          Didier Bur
                          Didieeeeeeeeeeer
                          OK OK I'm here. Don't shout 🀣
                          Pilou's workaround works great πŸ‘
                          DB
                            CadFather
                            true, i knew of the great Fredo trick, so far that is the way to go but segmentor will also change the shape of the curve while all i want is to divide it - something like this:
                            that ensures the gaps are the same but the 3d geometry is respected (perhaps the arc is part of a cylinder)
                            • perhaps i'm being too fussy? πŸ˜‰
                            • AnssiA Offline
                              Anssi
                              I would also like more control of the segment lenght of the Freehand tool, either beforehand or after drawing.
                              Anssi
