    Start_operation backward compatibility
    3 Posts 3 Posters 557 Views 3 Watching
      Jim
      Since I'm sure everyone wants to take advantage of the speed improvements in SU7 by using the new start_operation syntax:
      Sketchup.active_model.start_operation("Draw a Boat-Load of Geometry", true)
      and also retain backward compatibility; what's a good way to code this up? I guess this would work:
      if Sketchup.version.split(".")[0].to_i >= 7
      else
        Sketchup.active_model.start_operation("Draw a Boat-Load of Geometry")
      Is this a case where over-loading start_operation would be a good thing?
        azuby
        But when using old plugins with new Sketchup you need to make sure your overwriting code is loaded before the old plugins are loaded. Maybe you want to program a "Load Old Plugins" Plugin, put the old plugins into a separate folder, ...
        For your if-statement: Sketchup.version[0,1].to_i
        azuby
          Thanks for the tip. I just made use of it and it's working good. Operation took abtou 2 minutes in SU6 while no more than 30 seconds in SU7.
