    Help with Copy Along Path....
    13 Posts 4 Posters 976 Views 4 Watching
      Click Draw
      Hello gang,
      I am trying to use the copy to path tool but as seen in the screen shot, it's not doing what I'd like. Any ideas peeps?
      Thanks,
      Jeff
      Have I mentioned how much of a laugh I get out of some of the Signatures on here!
      • EarthMoverE Offline
        EarthMover
        Jeff,
        Make sure your lines are welded together and try making a component instead of a group. This way you can set your gluing axis.
        Content Creator at Skapeup
          Click Draw
          Ok...downloaded the weld ruby. Made a group and tried making component. Didn't work....I'm sad now. Any other ideas?
          Jeff
            Click Draw
            Been playing around and it seems to work on horizontal plane no prob....anyone else find this?
            • soloS Offline
              solo
              http://img377.imageshack.us/img377/1069/alongpath2zs3.gif
              http://www.solos-art.com
                Click Draw
                Thanks Solo,
                Kinda got it but have a look. I changed axis on left one....one on right and top is what i'd like. What do you think?
                • soloS Offline
                  solo
                  Ah! I see, um, I believe there is a plugin that can do it, but I have forgotten which one it is.
                  anyone?
                    Click Draw
                    It seems to what i want as far as layout and spacing as long as it's on the horizontal plane. You do have to have the part 90 deg. turned to how you actually want it to copy tho. Weird!
                    Jeff
                      Click Draw
                      well....I mean when you make the part a component, you have to make sure you pay attentionto the axis of the component. 😳
                      • soloS Offline
                        solo
                        I am trying to remember if indeed there is a ruby that copies perpendicular to the path.
                          Hi Jeff,
                          As I see you want the plugin not only to copy along the path but also to rotate it so that it is aligned (say) perpendicular to the path constantly.
                          If so, pathcopy is not the tool you need. There were some discussions about this a while ago and maybe there was some solution (modified or new script) but I cannot recall the result and cannot even find the topic now.
                            Click Draw
                            Well it seems to be fine if you do it along the horizontal plane. So....I guess it's a matter of making a multi-directional copy /follow by making all the pcs on the horizonal plane then pc them all together. Just not as hady. Oh well...thanks for your input guys.
                            Cheers,
                            Jeff
                              Click Draw
                              Done in 4 pcs....
