    Lights in su2pov3
    3 Posts 3 Posters 627 Views 3 Watching
    • 1 Offline
      10rsaxman
      I cannot insert lights using su2pov
      When I select either spotlight or pointlight from the menu, the properties dialog box appears, and I click OK. The su2pov layer is created. I click a location in the model for the location of the light, and the second and third points depending on the type of light, but no light is created.
      The su2pov_*.skp files for the lights are in the plugins folder.
      If I open the sample file, windmill.skp, I can change the properties of the existing lights, but cannot create new ones.
      • Didier BurD Offline
        Didier Bur
        Try this patch (delete old script and replace with this one).
        It's a major bug that occurs only when you have not SU2KT installed...
        su2pov3.rb
        DB
          aquisgrana
          This download helped me too Didier ! Merci...
          With kind regards
          Petronel
