    [Bug?] Pan "on border": Is this a known bug ?
    4 Posts 2 Posters 329 Views 2 Watching
      MarcioAB
      Please, see below if this is a known bug. Is there any way to prevent this (using API) ?
      Thank you
      Marcio
      Scenario
      1. Create a simple plugin (Tool) with the code below
      2. Activate the Tool ("t1" on Ruby Console)
      3. Drag the mouse with LButton down
      4. Keep moving the mouse towards the window frame borders
      5. The view will remain the same (as expected) but ...
      When the mouse is over the frame border (still with LButton down) the view will start to PAN. PAN down if the mouse is over top border, PAN right if mouse on left border and so on.
      class ToolTest
      nothing, empty
      def t1
      Sketchup.active_model.select_tool(ToolTest.new)
        RickW
        As far as I know, that is the intended behavior, consistent with how the native tools work.
        RickW
        www.smustard.com
          MarcioAB
          Well, I wonder why this SketchUP behavior ( starts to PAN when the mouse gets over the window frame border ) for API tools is normal. It's like as Orbit+Shift became active. What is the logic behind that ?
          Thank you
          Marcio
            RickW
            I think it was intended to avoid having to switch to Pan mode while drawing things.
            RickW
            www.smustard.com
