    How do I create a rb file
    3 Posts 3 Posters 445 Views 3 Watching
    • N Offline
      nrschmid
      I found a code online. I am not sure how to save this. Do I save it as a text file? I tried doing this and then saving it with an .rb instead of .txt in the plugins folder. It won't work. What am I doing wrong?
      Code is located at:
      http://download.sketchup.com/OnlineDoc/gsu6_ruby/Docs/index.html
      Thanks 💚
        Matt666
        Hi nrschmid !
        Codes in page you've mentionned are exemples. To try them, you have to :
        • copy opne code (for example "UI.beep")
        • Open ruby console, in the SketchUp Windows menu
        • Paste it in the console
        • Enter to validate.
        Sketchup returns a beep !
        Frenglish at its best !
        My scripts
          azuby
          What does it mean: "It don't work." Maybe you're using Windows and have enabled hiding file extensions. You should disable this in Windows.
          azuby
