    Install script options- help needed
    7 Posts 2 Posters 499 Views 2 Watching
    • garydornG Offline
      garydorn
      in SU ruby online help, it says ruby scripts can be installed a number of ways
      http://download.sketchup.com/OnlineDoc/gsu6_ruby/Docs/examples.html
      I am trying to setup mine as per the
      "Automatically Loading a Ruby Script Using the "require_all" Function"
      I am on mac OS 10.5.5
      I've made a myRubyScripts.rb file with
      home = File.expand_path "~"
      myrubyscripts = File.join home, "MyRubyScripts"
      require_all( myrubyscriptsdirectory )
      which I then placed in the SU plugins folder
      and a folder myrubyscriptsdirectory, which I then placed in in my user account and added a test plugin ; ContourMaker.rb
      when I start up SU I get this error message
      Error Loading File myrubyscripts.rb
      /Library/Application Support/Google SketchUp 6/SketchUp/Plugins/myrubyscripts.rb:1: parse error, unexpected $undefined., expecting '}'
      {\rtf1\ansi\ansicpg1252\cocoartf949\cocoasubrtf420
      what have I done wrong.
      thanks
        Jim
        Save your "myRubyScripts.rb" file as plain (ascii) text, not as Rich Text.
        • garydornG Offline
          garydorn
          according to Get info , the file is is plain text
          screen shot attached
          http://img383.imageshack.us/img383/6724/myrubyscriptsni6.th.png
          http://img383.imageshack.us/images/thpix.gif
            Jim
            garydorn,
            Welcome to the forum, by the way...
            Not being a Mac user, it's hard for me to say. It does appear to be a plain text file, but the code above (from your post) is the header information for a Rich Text Format file.
            • garydornG Offline
              garydorn
              thanks,
              I understand what you say, so I deleted that file, duplicated the utilities.rb file and replaced its text with the text suggested, then changed the file name to myrubyscripts and then opened SU
              I get this now
              Error Loading File MyRubyScripts.rb
              undefined local variable or method `myrubyscriptsdirectory' for main:Object
              thanks
              Gary
                Jim
                Because myrubyscriptsdirectory is an undefined local variable or method. πŸ˜„
                You set the variable named myrubyscripts in the previous line...
                • garydornG Offline
                  garydorn
                  I understand what you say about the text not matching so I played round with changing them so they matched, and after non-working numerous iterations,
                  it finally worked!
                  its now
                  require_all(myrubyscripts)
                  I think it worked because I eventually removed the spaces around (myrubyscripts)?
                  thanks for your help Jim
                  may this be of assistance to other Mac users.
