    My Ruby Questions
    4 Posts 2 Posters 572 Views 2 Watching
    • CadFatherC Offline
      CadFather
      looking at the ruby documentation ๐Ÿ˜ฎ i noticed there are only some of the commands ๐Ÿ˜ž
      i'm trying to find the command to bring the shadow settings dialog box up.
      anyone with this info - and if yes..where does one find unlisted actions?
      SECOND QUESTION: can i call a script from a custom command (or icon), even if the script is scrambled? say skin and bubble..
      • Didier BurD Offline
        Didier Bur
        Number 10533 will do it (i think)
        Check for "shadows here:
        # 10501; set view to Top
        # 10502; set view to Front
        # 10503; set view to Rear
        # 10504; set view to Left
        # 10505; set view to Right
        # 10506; set view to Bottom
        # 10507; set view to Axonometric
        # 10510; set render mode to Wire
        # 10511; set render mode to Hidden lines removal
        # 10512; set render mode to Surfaces Shading
        # 10513; set render mode to Transparency
        # 10519; set camera to ortho (removes perspective)
        # 10520; walk
        # 10521; display the System Preferences dialog box (Files tab)
        # 10522; removes axes display
        # 10523; pan
        # 10525; set the interactive eye height feature
        # 10526; zoom window
        # 10527; zoom extents
        # 10529; zoom out 2
        # 10531; toggle the Standard toolbar
        # 10532; toggle the Camera toolbar
        # 10533; display the Shadows Settings dialog box
        # 10537; toggle the Views toolbar
        # 10538; display the System Preferences dialog box (Display tab)
        # 10545; toggle Color ByLayer
        # 10546; toggle Shadows toolbar
        # 10551; toogle Large icons
        # 10576; toggle Render Mode toolbar
        # 10596; set Render Mode to No Transparency (Preferences)
        # 10597; set Render Mode to Wire (Preferences)
        # 10598; set Render Mode to Transparency (Preferences)
        # 10599; set Render Mode to Surfaces Shading (Preferences)
        # 10600; set Render Mode to Texture (Preferences)
        # 10601; set Render Mode to No Texture (Preferences)
        # 10602; toggle Shadows
        # 10603; toggle Profiles
        # 10604; toggle Extension Lines
        # 10605; toggle Jitter edges
        # 21019; Hide Status bar and VCB
        # 21020; Show Status bar and VCB
        # 21022; Hide Status bar and VCB
        # 21023; Display the 3D Text Dialog box
        # 21024; select the Measure tool
        # 21031; select the Freehand Draw tool
        # 21041; select the PushPull tool
        # 21048; select the Move tool
        # 21052; hide selected objects
        # 21056; Create face with selected edges closed loop
        # 21057; select the Protactor tool
        # 21060; display Components Window
        # 21061; toggle Draw toolbar
        # 21063; toggle Model Bounding Box display
        # 21065; select the Arc tool
        # 21067; creat a new Page
        # 21074; show the Materials Browser Window
        # 21076; display the Preferences dialog box (Text activated)
        # 21077; display the Tip of the day Window
        # 21078; select the Paint Bucket tool
        # 21080; display the Page Manager Window
        # 21082; display the Macros Dialog Box ???????????????
        # 21086; display the Components Browser Window
        # 21094; select the Rectangle tool
        # 21095; select the Polygon tool
        # 21096; select the Circle tool
        # 21098; open the Open Window
        # 21100; select the Offset tool
        # 21101; slect all objects
        # 21112; open the Import Window
        # 21124; launch the validity check tool
        # 21126; select the Axes tool
        # 21029; select the Rotate tool
        # 21032; toggle Layer toolbar
        # 21036; display the Save as Window
        # 21037; launch the Web browser and go to @Last home page
        # 21046; spin the model a full 360ยฐ and display report
        # 21047; fast Pick Time report (?)
        # 21049; open the Export model Window
        # 21169; select the Position Camera tool
        # 21170; display the Preferences, Tour Guide activated
        # 21180; create a new Page just right of selected page
        # 21200; display the Insert Image Window
        # 21220; display Help Window
        # 21222; launch the Web browser and go to @Last tutorials page
        # 21233; display Area of selected face
        # 21234; display Area of all faces with selected material
        # 21236; select the Scale tool
        # 21237; display the Export 2D Graphics Window
        # 21245; display a Polygon Offset Factors dialog box (?)
        # 21276; reverse selected face(s)
        # 21287; select the Divide feature
        # 21337; select the Section Plane Placement tool
        # 21354; open the Layer Window
        # 21386; open the Export Animation Window
        # 21405; select the Text tool
        # 21406; display Fog dialog box
        # 21410; select the Dim tool
        # 21433; toggle Edit toolbar
        # 21442; select the FollowMe tool
        # 21448; select the Axes tool
        # 21453; select all objects
        # 21460; display Licence
        # 21462; display Authorization dialog box
        # 21463; display un-authorizing message
        # 21464; display Open Licence files (Network) Window
        # 21466; display Quick reference Card in Adobe Reader
        # 21467; display Licences in use dialog box
        # 21469; zoom extents to selected objects
        # 21476; perform a non-planar check on selected objects
        # 21477; List accelerators in window
        # 21485; Erase selected objects
        # 21487; display Edit current material dialog box
        # 21485; Erase all new created pages
        # 21488; display Entity Info Window
        # 21490; display Soften Edges Window
        # 21491; display Profiles
        # 21492; display Extended Edges
        # 21493; display Jitter Lines
        # 21494; select Field of view tool
        # 21513; display a tree of the model with selectable items  !!!
        # 21520; Override Tile Rendering Size dialog box.
        # 21525; select the FollowMe tool
        # 21542; display the Insert Image Window
        # 21560 and up; Unknown, causes a runtime Error
        That's what I've found so far...
        I've done a loop in a script which increment action numbers and send them to Sketchup.
        Many bug splats occured of course...
        DB
          CadFather
          Thanks Didier, will surely be helpful to many..
          loop eh? ..and i feel like a genius when i manage to put an icon to a menu! ๐Ÿ˜Ž
            CadFather
            works beautifully! ๐Ÿ˜
