    [Request] Rotation for Individual Objects
    6 Posts 5 Posters 1.4k Views 5 Watching
    • A
      antantantant
      Hi all,
      Is there a way to rotate one object (group) according to its own axes while other stuff on the screen stand still? or Anyone has tried anything like that? Thank you!
      -Max
      • R
        remus
        You might be looking for something else, but with the SU rotate tool you can drag it along a line to set an axis of rotation.
        You can also rotate groups using the move tool, you first need to select the group->move tool and then grab one of the little red handles on the group that appear when you move your mouse over a face of the bounding box. It makes more sense when you do it...
        • J
          Jim
          @antantantant said:
          Hi all,
          -Max
          Hi Max. You just create a new Transformation object using any Point3d, Vector3d, and an angle; then apply it to the Group.
          The following rotates a Group around the it's own Z_AXIS by 90 degrees.
          # First, select a Group
          group = Sketchup.active_model.selection[0]
          group.transform! Geom;;Transformation.rotation(group.transformation.origin, Z_AXIS, 90.degrees)
          • A
            antantantant
            @jim said:
            @antantantant said:
            Hi all,
            -Max
            Thank you and sorry...
            What I really mean is "orbit". My question is:
            Is there a way to divide the screen into smaller scenes so that I can orbit each one independently?
            Thank you again!
            -Max
            • P
              psychomuffin
              That... would be neat. Multiple viewports. I could see aplications where one might want to see multiple sides at once. All panes would reflect the work you're doing.
              I like that. But I have now idea how that would get done though.
              -Scott
              • B
                Baker518
                I like the idea of multiple panes that are interactive. That might even make the inference issue that people have a bit less challenging too.
                Don't worry about things you have no control over. Worry is a lack of Faith!
