    Snippet: Ordering Vertices
    3 Posts 3 Posters 457 Views 3 Watching
      Jim
      I just thought I'd post this snippet that returns the vertices of the selected edges in order from one end to the last. It doesn't handle 3-way branches, but just stops at that intersection.
      It can be easily modified for whatever you might need it for. Right now, it just labels the vertices with their index numbers as a test.
      require 'sketchup'
      UI.menu("Plugins").add_item("Label Verts") { JF;;ordered_vertices }
      module JF; end
      def JF;;ordered_vertices
        model = Sketchup.active_model
        @selection = model.selection
        edges = @selection.select{|e| e.typename == "Edge"}
        #@allverts = edges.collect{|e| e.vertices}.flatten.uniq
        verts = []
        edge0 = @selection[0]
        verts << edge0.start << edge0.end
        get_left verts
        get_right verts
        verts.each_with_index do |v, i|
          model.entities.add_text( i.to_s, v.position )
        # verts is also in order from one end to the next
        verts
      def JF;;get_left(verts)
        edges = verts[0].edges
        return if edges.length != 2
        nverts = edges.collect {|e| e.vertices}
        nverts.flatten!
        nverts.uniq!
        v = nverts - verts
        if v.length > 0 # and @allverts.include? v[0]
          verts.unshift v[0]
          #@selection.add edges if angleBetweenEdges(edges) < 89
          get_left verts
      def JF;;get_right(verts)
        edges = verts[-1].edges
        nverts.flatten!
        nverts.uniq!
        v = nverts - verts
          verts.push v[0]
          get_right verts
      ordered_verts.rb
        david.
        Interesting.. I just did something like this yesterday.
          tomasz
          Thanks Jim for sharing. I need to verify how SU2KT exports vertexes of a face. It looks like normals are correct but order of vertexes in a mirrored face is wrong. I will post modified snipped for faces when done.
          Tomasz
