    Script for quicker intersect?
    5 Posts 3 Posters 697 Views 3 Watching
    • M
      marcus
      Hi all
      Just wondering if there is a script out there which will allow me to intersect an object with the model, and will automatically delete all the intersection lines and make faces. In other words so I could draw a cube, intersect a cylinder with it, run the script, and end up instantly with a cube with a hole, rather than having to manually delete all the lines and tidy it up. This would save me hours.....
      Marcus
        How would the script know what to delete?
        By the order of the clicks + Nature of the transformation (Difference Union Intersection ...
        It's Boolean Operations πŸ˜„
        A - B = C
        B - A = D
        A + B = E
        etc...
        πŸ˜‰
        • plot-parisP
          plot-paris
          wow, just imagine the boolean operations would work with nested components!
          you could create a complicated model, lets say of a sky scraper or a space ship, with grouping and all - and the "bite" chunks out of it πŸ˜„
          what happens, when several components are being cut though? will it affect all components the same, so the most possible ammount is cut off?
          ore will all cut components be made unique?
          or is it even possible to check if several components are cut the same way and only make a component unique when the cutting shape differes from the majority?
          http://img228.imageshack.us/img228/4851/booleancomponentstj0.jpg
            I never said that will be easy πŸ’š
            • plot-parisP
              plot-paris
              not easy - but deadly useful! πŸ˜„
