    Dwg versions and output reports
    4 Posts 2 Posters 517 Views 2 Watching
    • J
      James Fraser
      Hi. I'm trying to write a little script to handle the various exports I have to do at the end of each model, but I'm having trouble with dwg. model.export picks up that it is a dwg fine, but SU lets you export a few kinds of dwg (or dxf) and I can't see a way to specify that. I think it is exporting acad 2004 and I would like acad 2000. I'm not having much luck finding out if there is a way to specify that, does anyone know of anything that might help?
      Also, when some formats are exported they bring up a messagebox with some statistics in, the numbers are useful, but not so much if they are just shown on the screen. It's a long shot, but does anyone know of a way to grab that information as a string or have it sent to a file, or something. Failing that I might just put a questionnaire at the end.
      http://www.FormFonts.com
      • J
        JuanV.Soler
        YOU HAVE TO cLICK IN OPTIONS TO SEE IT, I THINK THAT IS.
        OBVIOUSLY IN THE RIGHT FORUM
        sorry 😒
        I´ll take it out in a while
        • J
          James Fraser
          Ah, ok, this appears to be a Mac problem, I had assumed that the PC version would be the same, but you are correct. On the Mac you don't choose dwg (rather than 3ds, say), you choose the type of dwg. See below.
          Don't worry, I am not that much of a noob.
          • J
            JuanV.Soler
            thanks
