    (REQ) 2D Drafting Tools
    2 Posts 2 Posters 478 Views 2 Watching
    • P Offline
      princedragoncok
      1. No idea if this is possible, but was wondering if it would be feasible to reduce line weight beyond what sketchup is capable of doing at the moment? (example: 'select line' -> then 'option' -> then 'reduce line weight') and,
      2. A hatching tool - where for example you select a face, then press hatch and the face is hatched with dashed lines or whatever.
      • jbacusJ Offline
        jbacus
        SketchUp can only render lines of 1px thickness or more. But by placing your SketchUp model in LayOut (you'll need SketchUp Pro), you can define the thickness of lines in points, not pixels- and thereby reduce the visual appearance of line weight.
        john
        "...exaggerate the essential and leave the obvious unclear." --Vincent Van Gogh
        John Bacus
        jbacus@sketchup.com
