    [Plugin] Remove Inner Faces
    23 Posts 15 Posters 33.3k Views 15 Watching
    • W
      wikii
      Plugin added below under this link.
      Does exist a ruby script for kill the internal surfaces but not the edges of these surfaces (after a Pushpull + Ctrl for example)?
      Why? Because when you export a Su file in OBJ to Zbrush for example, these intenal faces were not erased and make some disturb! πŸ˜’
      Resolved see here Thx Wikii & Matt666 😎
      face.jpgremove_inner_faces.zip
      • GaieusG
        It's not very difficult to do it manually either;
        http://www.sketchucation.com/forums/scf/viewtopic.php?f=22&t=905
          Yes I have seen this very useful tut, but for complex objects with thousand of internal faces, it's some painful πŸ˜„
          No possibility to test a surface'state in Ruby + SU?
          Select visibles face + Inverse Selection delete ?
          • free agentF
            free agent
            the subdive and smooth plugin set has a tool that does what ur asking for however u cant control how much it extrudes (which is a bit silly really) it just extrudes a bit to give you those extra faces then u have to manually drag it to the legth u want
            http://i167.photobucket.com/albums/u143/FreeAgent84/bug.gif
            • PixeroP
              Pixero
              Yeah, that tool would be great to have as a standalone script as an alternative to the normal pushpull tool.
              • W
                wikii
                module Wikii
                def Wikii.remove_inner_faces
                  fs=[]
                  Sketchup.active_model.selection.each{|x|
                  if x.typename=="Face"
                    to_be_delete=true
                    x.outer_loop.edges.each{|y|
                    if  y.faces.length<=2
                      to_be_delete=nil
                      break
                    fs << x if to_be_delete
                    Sketchup.active_model.start_operation "remove_inner_faces"
                    fs.each{|x| x.erase!}
                    puts fs.length.to_s+" faces removed !"
                    Sketchup.active_model.commit_operation
                  #Wikii.remove_inner_faces
                  @WiKii
                  How use that? With the ruby console? 😳
                  I am not ruby expert πŸ˜’
                  • M
                    Matt666
                    Hi Pilou !
                    1- Copy the code in a a new notepad file.
                    2- Copy this code below, in the file
                    if not file_loaded?("remove_inner_faces.rb")
                    	UI.menu("Plugins").add_item("Remove inner faces"){Wikii.remove_inner_faces}
                    file_loaded("remove_inner_faces.rb")
                    2- Save it as "remove_inner_faces.rb".
                    3- Move the file in plugins folder.
                    4- Restart SU.
                    πŸ˜‰
                    Frenglish at its best !
                    My scripts
                    • GaieusG
                      ... only forgotten to scroll the first code of Wikii so some lines are missing 😳 ...
                      There is a "Select all" link on the top of the code snipplet - if you use that, you can make sure not to leave anything out in the future (or click in the code field and hit Ctrl+A then Ctrl+C)
                        Yes for the next time it will be more easy! πŸ˜„
                          Ok I have made the steps above 1 2, 2(?) 3 4
                          but "syntax error line 16" (last line) ❓
                          Error Loading File remove_inner_faces.rb
                          C:/Program Files/Google/Google SketchUp 6/Plugins/remove_inner_faces.rb:16: syntax error
                          Edit 😳 :
                          I only forgotten to scroll the first code of Wikii so some lines are missing 😳
                          All works fine! πŸ‘
                          You are genious!!! β˜€
                          Ruby linked by Wiiki
                          • E
                            EA-d
                            [/attachment]
                            How about one for killing external surfaces, after an intersection of multiple groups, when forming internal models only (eg for export for light or acoustic modelling)? I'd like to place a marker (or the camera) inside my room and have a plugin automatically trim and delete any surfaces not reachable from that point. Sort of like doing a blow-mould!
                            Would be very handy!
                            • irwanwrI
                              irwanwr
                              merci monsieur Pilou πŸ‘
                              and wikii of course πŸ˜„
                              • L
                                Lain Iwakura
                                wikii, thank u very much. Great tool for retop.
                                  Seems you have this result with a blender of normal selections (right to left, left to right), Inverse Selection by Tig, Selection Toys by Thomthom...
                                  • J
                                    j_forrester
                                    Hi Guys,
                                    Just a quick one.
                                    Does this still work for Skecthup 2016? I have re-named the zip folder extension to ".rbz" hoping this would install it correctly. I says it did install but i cant seem to see it anywhere in the menus? Any help would be very much appreciated.
                                    • G
                                      glro
                                      @j_forrester said:
                                      Hi Guys,
                                      Just a quick one.
                                      just put this file in your plugins folder
                                      remove inner faces
                                      • J
                                        j_forrester
                                        @glro said:
                                        @j_forrester said:
                                        Hi Guys,
                                        Just a quick one.
                                        Thank you very much, worked perfectly!
                                        • PixeroP
                                          Pixero
                                          Just a side note.
                                          Sdmitch made a script for me that works like ctrl+pushpull without creating inner faces.
                                          It seems he hasn't released it publicly but you could perhaps ask him to release it if interested.
                                          • B
                                            blusben11
                                            I get this:
                                            Error: #<NoMethodError: undefined method file_loaded?' for main:Object> D:/Program Files/SketchUp/SketchUp 2015/Tools/remove_inner_faces.rb:23:in <top (required)>'
                                            Thanks in advance
                                            • 1 / 2
