    Shortcuts and keys in rubys collide
    9 Posts 5 Posters 1.2k Views 5 Watching
    • PixeroP
      Pixero
      Is there a way of having your own set of keys while in a ruby, and having the same shortcuts keys "deactivated" while that ruby is active" so they don't collide? I hope I make myself clear. 😕 I'm running out of free keys!
      • J
        Jim
        You are being clear, but I haven't found a way to suspend the shortcuts for any Tool I have written.
        • AdamBA
          AdamB
          Why don't you plug in another keyboard and double the number of keys.
          • PixeroP
            Pixero
            Seriously, could it be done through the SDK with some sort of connection so that it could be used in rubys?
            • tbdT
              tbd
              no.
              if you use too many keys than something is wrong with the design. try adding a UI (SU users are more visual), use multiple keyboard press (1st M press enter menu, 2nd M press move, ...)
              SketchUp Ruby Consultant | Podium 1.x developer
              http://plugins.ro
              • PixeroP
                Pixero
                What I'm after is a way of moving the camera in a game like way with the w,a,s,d keys.
                I could use the arrow keys but adding extra keys for elevation and such wouldnt be as easy.
                • tbdT
                  tbd
                  how about using Control as modifier ?
                  http://plugins.ro
                  • PixeroP
                    Pixero
                    Would "Caps Lock" work as a modifier?
                    Or would the "standard" shortcut keys still be enabled?
                    Or would it be possible using a keydown on Ctrl but no keyup in script?
                    • R
                      RickW
                      You could capture keystrokes in a modal webDialog - this will override any SU keyboard shortcuts - but beware irritating users who are used to using a shortcut for "select" that effectively cancels any active tool. Either query the shortcut list for the "select" shortcut and use it to cancel your modal webDialog, or create a really obvious "cancel" button or key.
                      RickW
                      www.smustard.com
