    Script check-->materials
    4 Posts 3 Posters 684 Views 3 Watching
    • P Offline
      Pout
      This is my script:
      ss.each{|e|
           mat= e.get_attribute 'xdid_dict', 'sumatdisplay'
           if not mat
      	     UI.messagebox("no material specs in dict.")
      	     if e.material.display_name
              UI.messagebox("has a material")
             else
             UI.messagebox("has no material")
      What i want it to do is:
      A. See if the selected object already has dictionary attributes defined:
      ss.each{|e|
           if not mat
      These values are written in an earlier stage after some command is executed (this command writes the folowing values:
      orig_name=e.material.name
                 orig_materialtype=e.material.materialType
                 orig_display_name=e.material.display_name
                 orig_texture=e.material.texture
                 orig_color=e.material.color
                 orig_alpha=e.material.alpha
                 e.set_attribute 'xdid_dict', 'sumatname', orig_name
                 e.set_attribute 'xdid_dict', 'sumattype', orig_materialtype
                 e.set_attribute 'xdid_dict', 'sumatdisplay', orig_display_name
                 e.set_attribute 'xdid_dict', 'sumattexture', orig_texture
                 e.set_attribute 'xdid_dict', 'sumatcolor', orig_color
                 e.set_attribute 'xdid_dict', 'sumatalpha', orig_alpha
      Question: Isn't it just possible to get the ID of the material the object has? Instead of the need to keep all these seperate variables?
      B. Now i have noticed that fresh created objects who have no material attached do not have any material values (how does SU stores their color-visual representation?). So i check these:
             else
      This does not work. If there is no material assigned, then the script stops and does not sign "has no material". If there is a material assigned then the message "has a material" shows up ok.
      Now maybe i'm a bit on the wrong path here, so i'll try to explain what i try to do:
      Store the material-color (the visual part of an entity-group-...) in an attribute dictionary.
      So when i do changes to them then i can get the original back.
      It would be great if each material in SU had an ID and each object had this ID so i just have to store that one in the attribute dict.
      Thanks!!
        Jim
        Have a look at the Greyscale plugin recently posted. It saves a material's original color before changing the material's color to greyscale.
        404 Not Found
        (www.sketchucation.com)
        • fredo6F Offline
          fredo6
          Pout
          You should turn on the Ruby Console, and use "puts <message>", instead of UI.messagebox. This will help you to understand what's going wrong.
          You could also take some inspiration from an old script I wrote, which toggle the selection between xray and normal.
          I reattach it here
          XraySelection.rb
          • P Offline
            Pout
            works, thank you very much πŸ˜„
