Plugin question. updating plugins.
hi i downloaded a plugin today from smustard. it was called 'offset' script/plugin i don't really the difference yet? anyway, the file was called 'offset' and when i installed the offset file, after i was done adding all the smustard files that i had downloaded, i got a message, 'do you want to replace offset file 4.16kb with this one 6.92kbs? what does this mean? is the 4.16kb file a pre sketchup 6 file and the 6.92kb the latest version for 6?
Im guessing it means youve already got a plugin called offset in your plugins folder. Im not sure of the specifics though, so just make a backup of your plugins and try replacing the old one in the proper SU folder.
When you go to replace it, look at the date that each was created on. That can help determine which is newer.
Chris
for scripts that you bought from Smustard you could download their "MySmustard" plugin which will check the installed (paid/bought) plugins against your account. It's the easy way of always being up to date.
Register LoginAdvertisement
