    Plugin question. updating plugins.
    4 Posts 4 Posters 447 Views 4 Watching
      Tekkybot
      hi i downloaded a plugin today from smustard. it was called 'offset' script/plugin i don't really the difference yet? anyway, the file was called 'offset' and when i installed the offset file, after i was done adding all the smustard files that i had downloaded, i got a message, 'do you want to replace offset file 4.16kb with this one 6.92kbs? what does this mean? is the 4.16kb file a pre sketchup 6 file and the 6.92kb the latest version for 6?
        remus
        Im guessing it means youve already got a plugin called offset in your plugins folder. Im not sure of the specifics though, so just make a backup of your plugins and try replacing the old one in the proper SU folder.
        • Chris FullmerC Offline
          When you go to replace it, look at the date that each was created on. That can help determine which is newer.
          • jujuJ Offline
            juju
            for scripts that you bought from Smustard you could download their "MySmustard" plugin which will check the installed (paid/bought) plugins against your account. It's the easy way of always being up to date.
