    Sketchup Web Exporter
    26 Posts 10 Posters 5.4k Views 10 Watching
      4mb.... i think?
      I use PS for animated gif so i know it gives good control over file sizes. The thing with your gif is that members may miss the animation element if they read later/earlier posts. Still pretty neat output though.
      • D
        driven
        you can get them straight out of SU, but the settings are a bit of a learning curve.... will repost when I work it out.
          No image?
          • D
            driven
            test....no.11
            convert -set -delay 400 -colorspace rgb -ordered-dither o8x8,8,8,4 -dispose 1 -depth 8 -loop 0 -scale 100% *.jpg macHack14.gif
            very grainy as big gif, but getting better
            manually reordered the sequence, runs fine from file,
            point is do you want to 'fix' the PC version... to not zoom out.
            • D
              driven
              i was trying to upload, others and forgot i was in edit mode, not new...
              the limit is 2MB, can I get a raise, it's so hard to meet this one 1.6MB but half size.
              IM Settings convert -set -delay 400 -colorspace rgb -ordered-dither o8x8,8,8,4 -dispose 1 -depth 8 -loop 0 -scale 50% *.jpg macHack16.gif
              best compromise...
              john
              • D
                driven
                in viewerthe buttonin Sketchup [window zZoomed to AR]
                This is my actual selection and the resultant output file ready for playback in SU.
                • 2 / 2
