    Errors
    4 Posts 4 Posters 1.4k Views 4 Watching
      rodsheart
      everytime i open SU i get the following errors
      what do i need to do ??
      Error Loading File auto_centerpoint.rb
      No such file to load -- ruby/singletonError Loading File VRayForSketchup.rb
      1114: A dynamic link library (DLL) initialization routine failed. - C:/PROGRA~1/Google/GOOGLE~1/Plugins/VRayForSketchUp/VRayForSketchUp.soError Loading File _MENU_00_FIX.rb
      No such file to load -- Scripts/FIX/MAKEFACES.rbError Loading File _MENU_00_POWER.rb
      No such file to load -- Scripts/POWER/PipeAlongPath.rbError Loading File _MENU_01_LAND.rb
      No such file to load -- Scripts/LAND/ContourMaker.rbError Loading File _MENU_02_ARCH.rb
      No such file to load -- Scripts/ARCH/STAIRCONCTOOL3.RBError Loading File _MENU_03_DRAW.rb
      No such file to load -- Scripts/DRAW/BEZIER.rbError Loading File _MENU_04_SHAPES.rb
      No such file to load -- Scripts/SHAPES/SHAPES.rbError Loading File _MENU_05_EDIT.rb
      No such file to load -- Scripts/EDIT/ROTIX.rbError Loading File _MENU_06_SELECT.rb
      No such file to load -- Scripts/SELECT/HIDE_FACES_EDGES.RBError Loading File _MENU_07_RENDER.rb
      No such file to load -- Scripts/RENDER/su2kt.rbError Loading File _MENU_08_TOOLS.rb
      No such file to load -- Scripts/TOOLS/DISPATCH_OBJECTS.RBError Loading File _MENU_10_CONTEXT.rb
      No such file to load -- Scripts/CONTEXT/DROP.rbError Loading File _MENU_11_TEXT.rb
      No such file to load -- Scripts/text/find_and_replace_text.rbError Loading File _MENU_12_CAMERA.rb
      No such file to load -- Scripts/CAMERA/CAMERA_PARAMETERS.rb
        Well, I am not a script cerator but from this it seems to me that your Plugins folder is screwed up big time. There shouldn't be a Scripts folder (with all the subfolders) there IMO.
        Could you take a screenshot of your folder structure of SU (or at least the Plugins folder within the SU application under Program Files)?
        In the meanwhile, I'll move your topic to the Ruby Forum because the guys there will spot the errors easily and I'm not sure if all of them visit this forum.
        • CadFatherC Offline
          CadFather
          looks like you are using rubyset, a collection of freeplugins which does use a folder called scripts.
          if you don't already have it, my suggestion is to get a copy of rubyset 6 (RS6) http://www.special.eclipse.co.uk/sketchup_training/sketchup_training.html - (navigate to resources and download the set). in the same page you will also find the instructions.
          in any case, delete (or copy elsewhere) your plugins folder (if you have other scripts you have purchased, back them up to replace them later) place the RS6 'plugins' folder into your google sketchup directory. then pick the contents of the RS6 'tools' folder and drop them into your existing tools folder overwriting all files.
          let me know how you get on
            Jim
            I guess I would start all over again. See this post post for the default setup of the Plugins folder.
            http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=6952&hilit=+default
