    Help needed with a texture problem
    6 Posts 4 Posters 649 Views 4 Watching
    • EdsonE Offline
      Edson
      i am having a problem with textures in a context building of a competition i am doing. pict 1 shows the bldg how it is modelled in SUp. pict 2 shows how it is coming out of render (podium). one texture is taking over the whole thing. i entered the group and exploded everything inside it. what i got from this was just the reverse behavior: the beige texture took over instead of the reddish one.
      could anyone help with it?
      Pict1: the original textures
      how it is coming out of podium
      http://www.mahfuz.arq.br
        remus
        I think youd be better of asking about this on the podium forum.
        • EdsonE Offline
          Edson
          i have. thanks.
            tomsdesk
            Edson, have you tried exploding the outside group? I know nothing about Podium, but I remember having a similar strangeness in SU and finally found I had inadvertantly given the group a texture other than the default...I guess there was an internal confusion about which material to read?
            2.5D Trees & Shrubs!
            • EdsonE Offline
              Edson
              tom,
              i think you nailed the problem: it surely has been assigned a color/texture (by one of my students...). i will try exploding everything to see if it helps.
                lapx
                Also, have you made sure all faces are front face. πŸ˜„
