    ๐Ÿ”Œ Smart Spline | Fluid way to handle splines for furniture design and complex structures. Download
    Plane on a coneyor belt
    110 Posts 14 Posters 6.0k Views 14 Watching
    • Alan FraserA Offline
      Alan Fraser
      True Remus, but considering practicalities like that brings the whole argument crashing down, because the bearings on the conveyor motor would fail long before those on the aircraft wheels...they are carrying a much heavier load with a massive amount of torque. There is virtually no torque on the aircraft wheels...they're essentially freewheeling. If the conveyor motor fails, the plane takes off....end of argument. My point was that you can't start contemplating actual shortcoming of the plane's mechanics while allowing the conveyor mechanism to have unlimited magical powers.
      3D Figures
        remus
        Its not a shortcoming in the physicalities though, its a problem with the theoretical physics/mathematics behind the problem.
        • P Offline
          pichuneke
          Any volunteer to make the model in Sketchup Physics and see what happens? ๐Ÿคฃ
          Forgive my spanglish...
            Alan Fraser
            There isn't any problem with the physics/mathematics behind the problem. The physics say that the plane will take off. The calculations really aren't that difficult. It's the seemingly persistent...and entirely intuitive...notion that the conveyor will have any significant effect on the plane that's the problem.
            The friction would be F=uR, where F= friction force, u is friction coefficient, and R= weight. The friction is constant (other than the plane getting lighter as it approaches takeoff speed); therefore the speed of the conveyor is totally irrelevant....nowhere does its velocty (v) appear in the frictional calculation.
            This frictional force is not great. There are YouTube videos of people pulling Lear jets with their teeth. They are overcoming not only the friction, but also the inertia.
            If the speed of the conveyor is irrelevant...and it is...it doesn't matter whether it's matching the speed of the plane or the rotational speed of the wheels. It's irrelevant in both cases.
            As long as the forward thrust of the plane is greater than the friction (not exactly difficult) it will accelerate and take off as normal. It wouldn't surprise me to discover that a fighter jet could take off even with its brakes on. All it has to do is burn rubber for a few seconds. In such a case, of course, the conveyor would be stationary as the wheels wouldn't be rotating at all. ๐Ÿ˜‰
            3D Figures
              remus
              I was refering to the fact that for the wheels to be moving forward they must spin infinitely fast+the speed of the plane.
                Alan Fraser
                For any matter to reach an infinite speed would require all the energy in the Universe.
                Perhaps the second part of the question ought to have asked whether such a model was possible at all rather than asking something more specific like whether or not the plane could take off. If the model isn't valid then whether the plane can take off or not ceases to have any meaning
                3D Figures
                  remus
                  But the model does work (to an extent) and the plane cant take off.
                  Th reasoning: if the plane has any forward velocity this sets the wheels off in to a cycle whereby the wheels keep rotating faster and faster forever, this is impossible so the plane cant have a forward velocity.
                  • plot-parisP Offline
                    plot-paris
                    but the question was what happens, if the conveyor prevents exactly this. and for this question is theoretical we can asume that the conveyor can keep up to the speed (we could create a huge one with incredible speed after all).
                    is it right, if we say:
                    • theoretically the conveyor could stop the plane from taking off, because there is no windpressure on it's wings to take off
                    • practically the speed of the conveyor necessary to stop the plane from moving forward is impossible to reach with todays technology
                    (I think that is a satisfying solution, because it shows, that we all where right - only approaching the problem from differend ends. ๐Ÿ˜‰ )
                    • P Offline
                      pav_3j
                      i like this response, it's clear, concise, correct, and most importantly has a reference to chuck norris.
                      pav
                      Just won the 'Who is Least Competitive Championships' where trying to win will make you lose. Trying to lose makes you win which makes you lose. Not trying at all makes you lose which makes you win which makes you lose.
                        remus
                        Fair point about the conveyor spinning infinitely fast, although the wheels would then be doing the same speed as the conveyor belt, and as theyre going in opposite directions that means no forward velocity.
                        As for practicalaties, i dont think theres a lot of point discussing them in this situation.
                        EDIT: to sum up my argument, whatever speed the wheels on the plane are rotating at is exactly matched by the conveyor belt, so the plane cant have a forward velocity as then the the infinite cycle starts. Even if we then follow this through both the speed of the wheel and the speed of the conveyor belt tend to infinity, and so are the same once more, thus no take off.
                        • Chris FullmerC Offline
                          yup, Alan is still right on this. Its that simple. Theortically and practically, the plane still takes off.
                          Remus, ask yourself this: "Where does a car get foraward motion from?" and next "Where does a plane get forward motion from?"
                          Plot-Paris, the theortical part of you situation is wrong, because a plane doesn't need pressure on its wings to move forward. I thought it did earlier in this thread, but see now that is wrong. It moves forward by sucking air through its propller/turbine. It does not need any lift whatsoever under its wing to move forward. So the engines alone are capable of pushing it forward through the air. Therefore it doesnt matter what the wheels are doing, they just spin. The plane only moves in relation to the air around it, even when its on the ground. That is a very important phrase.
                          Chris
                          All my Plugins I've written
                            Alan Fraser
                            @ Remus. No. Acceleration to infinity is impossible. That means that the entire model is invalid, it does not mean that the plane can't take off. You could just as easily argue that the travelator can't accelerate to infinity, therefore the plane CAN take off.
                            The wheels could only spin infinitely fast if the conveyor was also travelling infinitely fast. In practice the wheels wouldn't spin infinitely fast...they'd go as fast as they could, then they'd skid, adding a slight extra friction, but nothing that amounted to anything serious.
                            @ plot-paris. No. For the umteenth time, the speed of the conveyor is irrelevent. The conveyor can only exert a small amount of reverse force in the form of friction on the plane. This is equivalent to (depending on the size of the plane) between 1 manpower and a couple of horsepower. It is also constant whatever the speed of the conveyor. Admittedly, more work will be done as the conveyor accelerates and the wheels spin faster. However, all that extra energy will be supplied by the conveyor, not deducted from the plane's thrust. It is the conveyor that is making the wheels spin faster than they would ordinarily need to. That work energy is rotational, not directional; it has no effect on the forward motion of the plane.
                            The plane, on the other hand has its full forward thrust available. It will move forward through the air nearly as normal. Where are you getting this no wind pressure from?
                            Are you really saying that a man with a rope tied around the tail of a plane can stop it taking off by pulling backwards? Chuck Norris could, of course. ๐Ÿ˜‰
                            3D Figures
                              plot-paris
                              of course we all know, that chuck norris would never do that, because he enjoys us mortals struggling with this problem ๐Ÿ˜‰
                              ok. we all agree with the fact, that the plane has to move forward to take off, right (because it needs to move foreward to get air pressure under it's wings). of course we all know as well, that to achieve this foreward movement, the plane doesn't need this upward lift (that is merely a result of the forward movement).
                              so our whole difference lies in the question, if the conveyor, moving backwards, can transfer any energy in form of motion through the wheels to the plane.
                              you say that the wheels do not have the option to transfer this energy to the plane whatsoever.
                              and I completely disagree with that. let me tell you again, why:
                              if you place pav's skate board on the treadmill again and switch it on, it will be transported backwards and fall off.
                              to prevent this, you hold your finger against the board - it stays stationary
                              if you remove your finger, the board will move backwards and fall off!
                              that demonstrates, that energy was necessary to keep the board in place.
                              the kinetic energy was transferred from the treadmill, through the wheels, to the board due to the frictional resistance - thereby was transformed to heat-energy in the wheels.
                              if you speed up the treadmill, the tyres will heat up quicker, than with low speed. at the same time you need slightly more energy to keep the board in place on the treadmill.
                              and that demonstrates, that increasing the speed of the conveyor increases the kinetic energy transferred to the plane - therefore the theoretical possiblility to prevent the forward-movement of the plane is proven!
                              ps: nice argumentation with infinity, remus. would never have thought to take it thus far ๐Ÿ˜„
                                remus
                                Ok, i think ive come up with a neat mathematical way of explaing this.
                                First, the question states that the conveyor belt will always match the speed of the wheel, so if we call wheel speed 'x' and conveyor speed 'y':
                                x=y
                                For the plane to take off it must have forward velocity of say 100 mph, this can be expressed as:
                                y+100
                                if we take to be any speed the conveyor had before the forward velocity.
                                so at the moment of take off:
                                x=y+100
                                Looking back at our first equation
                                x=y
                                and
                                x=y+100
                                cannot both be true at the same time.
                                EDIT: i realised a flaw in the original argument, and changed it.
                                  plot-paris
                                  I am afraid, this is not correct, for you assume that the entire speed of the conveyor (Y) will be transferred to the plane, which is not correct.
                                  we had to introduce the variable of the frictional resistance (f). so the objective speed of the plane (OS) would be (the speed the plane normally would travel is hence called SuS (for Subjective Speed)):
                                  OS = SuS - Y*f
                                  [Edit]
                                  and to calculate Y:
                                  Y = SuS*f
                                  [Edit2]
                                  Sorry, wrong again:
                                  OS = SuS - Y/f
                                  Y = SuS*f
                                  therefore: OS = Sus - Sus*f/f
                                  therefore: OS = 0
                                    remus
                                    The basic premise behind the argument stays the same, though.
                                    EDIT: (i think ๐Ÿ˜• )
                                      plot-paris
                                      pav, we two have to agree with one of the answers for this question and then produce a SCF-TV episode.
                                      because we all know: what you see on television news is bound to be true ๐Ÿคฃ
                                      • P Offline
                                        pav_3j
                                        exactly!
                                        TV never lies, it's the people in front of the cameras that do.
                                        he he
                                        pav
                                          Alan Fraser
                                          There is some really bad maths and physics going on here. Mix that with architecture and it gets a little scary. Make sure you have good engineers guys. ๐Ÿ˜‰
                                          Sorry, but I have now lost the will to live.
                                          3D Figures
                                            plot-paris
                                            Alan, if you can explain to me in a sensible way, why the skateboard should NOT fall off the treadmill (my example from 8 posts above), when no finger is holding it on it's position, you will have convinced mee...
                                            • 6
                                            • 5 / 6
