    Plane on a coneyor belt
    110 Posts 14 Posters 14.9k Views 14 Watching
    • R
      remus
      A conundrum for your great minds:
      A plane is standing on a runway that can move (some sort of band conveyer). The plane moves in one direction, while the conveyer moves in the opposite direction. This conveyer has a control system that tracks the plane speed and tunes the speed of the conveyer to be exactly the same (but in the opposite direction). Can the plane take off?
      • H
        HFM
        Well, you clearly don't watch MythBusters 🤣
        • soloS
          solo
          no!
          The plane would be at a stand still relative to the environment thus no 'lift' would be generated.
          http://www.solos-art.com
          • R
            remus
            To argue the point: isnt it like a glider being towed by a winch? the jets/winch are an external force operating seperately to the wheels, so surely the plane will gain forward velocity (and so lift.)
            • StinkieS
              Stinkie
              I'm no physicist, but I think Remus is right. The plane would take off.
              • soloS
                solo
                The glider that is being towed is moving relative to the physical ground and in doing so air is moving across and under it's wings which in turn will generate lift, the plane on the conveyor is not moving relative to the physical ground and no air is moving fast across and under it's wing thus no lift.
                • Chris FullmerC
                  Not like a glider really, no. Lift is gained by air rushing towards the plane's wing, and getting pushed underneath it. Thus creating a bed of air that is so dense it can support the weight of the aircraft essentially. But it is the air rushing towards the wing that is important, not the ground speed or relation to any other object. So the plane could sit perfectly still and have a huge amount of air blown towards it and it could lift off that way. That is a wind tunnel, which works. 😉
                  Chris
                  All my Plugins I've written
                  • Chris FullmerC
                    Just to clarify, its not about the speed relative to the ground at all. As in a wind tunnel, the ground and the aircraft move at the same speed - zero, while the air is what is moving. The plane only gets lift in relation to the wind speed coming towards it.
                    • soloS
                      solo
                      Basically for the example of the conveyor, there will be no rushing wind, hence no lift as the plane would in essence be stationary relative to the ground and unless a mass of rushing wind suddenly came at it from the front it would remain grounded.
                      • R
                        remus
                        Chris, i dont understand why this has nothing to do with ground speed. If we imagine a calm day there will be no wind speed, so the plane must first achieve ground speed to gain wind speed.
                        • P
                          pav_3j
                          no way is that bad boy taking off.
                          i'll try it at the gym tomorrow, i'll attach some wings to my sides and jump on the treadmill.
                          if this did work, airports would be a hell of a lot smaller. he he
                          pav
                          [EDIT] Just walked into my kitchen about 6 meters away. poured a glass of milk, and walked back to the computer, and my A level Physics kicked in, and i realised what a fool i had been.
                          the plane does of course take off.
                          feel like such a fool, thank god for the EDIT function eh!
                          Just won the 'Who is Least Competitive Championships' where trying to win will make you lose. Trying to lose makes you win which makes you lose. Not trying at all makes you lose which makes you win which makes you lose.
                          • soloS
                            solo
                            If it did indeed work then I believe the next aircraft carriers will have treadmill decks and not catapult launchers.
                            Could a plane then land on a conveyor too?
                            • D
                              drewpoeppel
                              http://mythbusters-wiki.discovery.com/page/plane+on+a+conveyor+belt
                              • soloS
                                solo
                                Ah!!
                                If the question was asked like that in Myth busters:
                                Can an airplane on a conveyor belt running in opposite motion to the airplane's tires at the same speed keep the plane from taking off?
                                Tires!
                                Now that changes everything since the tires are not the propulsion method of a plane, hence the propeller/jets will move the plane forward and lift will be possible. The top question indicates that the plane would be stationary.
                                • Chris FullmerC
                                  I agree Solo. I was under the impression we were talking about a plane w/o a propulsion method. But thinking of it in terms of a jet sucking in air, plus the conveyor belt underneath it, than that changes everything.
                                  Still though, the speed of the aircraft in relation to the ground is not important, which is precisely why the excercise works. The plane can sit still as long as it has enough lift. So its engines are strong enough to suck in the amount of air required to give it loft. Once its wings have enough air flowing over them (under), the aircraft will lift up off the conveyor belt and should then move forward.
                                  So if you've ever seen a bird soar, but in place, its the same idea. I saw a crow floating perfectly still with its wings out, not moving because it found a spot where the wind was flowing steadily at the same speed. It was hitting a freeway berm and the wind headed upwards. So the crow could float on the air w/o having to flap its wings or move forward. So the crow and the ground were moving the same speed, it was the wind that was moving.
                                  Its an interesting question for sure. More complex than I had understood the first time I read it (obviously).
                                  I saw the 2 mythbusters guys on TV last night on Dave Letterman (late night TV show). It was interesting. They also have an open call for volunteers to help hold mirrors in September if you are in the San Francisco area.
                                  Chris
                                  • plot-parisP
                                    plot-paris
                                    if we asume that the conveyor belt always keeps the same speed as the airplane's forward motion (which is, what they want, if I understood correctly), thus keeping the jet at zero speed relative to it's surroundings, it can not take off, no matter if it is an aircraft with a propeller, jet engine or even rocket propulsion.
                                    the only thing that matters is, like explained several times already, the relative speed of air rushing past the planes' wings.
                                    If we use a jet fighter instead of a glider it only means, that we need even more speed to take off, because the wings provide a smaller surface.
                                    and because the formula is
                                    air-pressure x wing-surface
                                    (at least I think it is like this 😉 ) the variable air-pressure needed to increase if the wing-surface is reduced.
                                    you can think it the other way arround. if a plane flew happily through the sky and suddenly a big wall (lets say a ufo) would decide to fly directly in front of it with the same speed, thus providing slipstream, the poor plane would simply fall out of the sky... 😄
                                    • Chris FullmerC
                                      @plot-paris said:
                                      ...thus keeping the jet at zero speed relative to it's surroundings, it can not take off, no matter if it is an aircraft with a propeller, jet engine or even rocket propulsion.
                                      the only thing that matters is, like explained several times already, the relative speed of air rushing past the planes' wings...
                                      Yes, but your thinking of it how I was too. Its important to note that the question doesn't say that the engines are off, it just says that a conveyor belt keeps it from moveing forward. So the engines are on full blast, thereby sucking the air towards them. So the plane is not standing still relative to its surroundings, because its surroundings are rushing towards it through its propellers/jet engines at a high enough velocity to achive lift, even while sitting still on a conveyor.
                                      Chris
                                      • soloS
                                        solo
                                        If it's a Harrier then it WILL take off!
                                        http://img362.imageshack.us/img362/8499/harrierneargroundgv7.jpg
                                        • Alan FraserA
                                          Alan Fraser
                                          The problem is the instinctive analogy with a car...which would remain motionless in such a situation. In fact, because the plane gets its propulsion from its props/jet turbines, as soon as the engine is fired the plane will move forward through the air, regardless of what the conveyor belt is doing. The conveyor could be moving at light speed, all it will do is make the plane's wheels spin faster than they normally need to.
                                          A much closer analogy would be if you were wearing roller skates and attached to a winch which pulled you forward at 30 mph, while the conveyor was rolling backwards at 30 mph. The result would be that you would still move forward at 30 mph...but the skate wheels would be doing 60.
                                          3D Figures
                                          • P
                                            pav_3j
                                            just had a full blown office argument about this, for about an hour on an off, (and this is no exageration).
                                            only one other person in my office agreed with me on the plane being able to fly, and together, we had to convince the other 6 in the office they were wrong.
                                            not an easy task, but one i enjoyed none the less.
                                            at one point, someone went to their car and got out a toy car ( i presume their kid left it in there!) and did a demonstration as to why it would not work.
                                            after it was pointed out to him that a cars propulsion was very different from a planes he totally understood. and also cherried up like i have never seen before, it was hilarious!
                                            thanks remus, hours of fun!
                                            pav
                                            • 6
                                            • 6 / 6
