    Candelight
    6 Posts 4 Posters 572 Views 4 Watching
    • N Offline
      nomeradona
      candle has been modelled using follow me tool. wick with pipe along path.
      to smoothen i used 48faces instead of the default 24.
      the light is a simple 2d texture with opacity map and emmisive layer using vray. candle texture is using refraction with .01 folg multiplier in vray too.
      http://img65.imageshack.us/img65/6528/candlelightkn5.jpg
      visit my blog: http://www.nomeradona.blogspot.com
      • soloS Offline
        solo
        Nice one nomer, and great to see you around again.
        http://www.solos-art.com
        • N Offline
          nomeradona
          wow solo that was quick...im really on and off right.
            remus
            Nice render, cheers for the explanation as well, ive been pondering how to do open flames for a while and your method seems to give pretty good results.
            • K Offline
              kwistenbiebel
              Thanks Nomer for both the nice image as the short (but really good) how-to explanation.
              • N Offline
                nomeradona
                well im glad you understand clearly the explanation. its actually difficult to achieve the gradient in using 3d. for that light whilst i have used 2d image. the only problem of course when you change your viewing angle. unless you or our friend solo has another workaround.
