    How to receive correct coordinates of all vertexes?
    3 Posts 2 Posters 636 Views 2 Watching
    • A
      AlexMozg
      How to receive correct coordinates of all vertexes in selection, including all the nested groups and components.
      Multiplication of transformations far not always gives correct result, especially if for any nested group(component) of an axis do not coincide with an axis of group(component) in which it is enclosed.
      I was trying so:
      @lines = []
      extract_lines(group.entities, (Geom;;Transformation.new))
      def extract_lines(ents, tr)
      	ents.each do |e|
      		if e.typename == "Edge"
      				line = [e.vertices[0].position, e.vertices[1].position]
      				line[0] = tr * line[0]
      				line[1] = tr * line[1]
      				@lines << line
      		elsif e.typename == "Group"
      			extract_lines(e.entities, (e.transformation * tr))
      		elsif e.typename == "ComponentInstance"
      			extract_lines(e.definition.entities, (e.transformation * tr))
      But here the relative positioning of groups concerning a model is not considered.
      There are ideas as it to make?
      • T
        tomasz
        Hi Alex,
        Your sample code looks fine for me. Could you post a simple model showing wrong coordination's readout?
        Tomasz
        • A
          AlexMozg
          Correctly it will be whew:
          @lines = []
          extract_lines(group.entities, group.transformation)#!!!
             ents.each do |e|
                      @lines << line
                   extract_lines(e.entities, (tr * e.transformation))##!!!
                   extract_lines(e.definition.entities, (tr * e.transformation))#!!!
          and it works!
