    πŸ€‘ SketchPlus 1.3 | 44 Tools for $15 until June 20th Buy Now
    Problem installing joint push pull
    6 Posts 3 Posters 3.4k Views 3 Watching
      seanheadrick
      I'm having a problem loading the joint push pull ruby. I've downloaded and installed a few zips so I think I understand the general procedure. Looking at the installation guide in the JPP_Dir folder,when I extract the zipped files i should have Lib Traductor.rb, jointpushpull.rb, and lib traductor.def. Also the folder JPP_Dir. I'm not seeing the lib traductor.def, although I installed tools on surface this morning and it also used the Lib traductor .def that I am not seeing in the unzipped "jointpushpull".Tools on surface installed o.k.When I start SU after the install I get a syntax error saying the joint push pull could not load. What am I doing wrong? ❓
      DO OR DO NOT, THERE IS NO TRY.
      • fredo6F Offline
        fredo6
        A few hints and questions
        • LibTraductor should be the version 20 Jan 08
        • Don't worry with LibTraductor.def. It is just useful to force a particular language and not mandatory at all
        • Are you on PC or Mac?
        • Is Tools on Surface working fine?
        • Can you turn on the Ruby console and load manually the script (type load 'JointPushPull.rb'. Then can you post the output arror messages in this thread
        Fredo
          seanheadrick
          %(#FF0000)[Error Loading File jointpushpull.rb
          C:/Program Files/Google/Google SketchUp 6/Plugins/jointpushpull.rb:2356: syntax error
          menu.add_item(Traductor[DLG_MnuRedo) { JointPushPull.redo }
          C:/Program Files/Google/Google SketchUp 6/Plugins/jointpushpull.rb:2378: syntax error]
          this is what comes up when i start SU.
          %(#FF0000)[Error: #<SyntaxError: (eval):149:in `load': C:/Program Files/Google/Google SketchUp 6/Plugins/jointpushpull.rb:2356: syntax error
          C:/Program Files/Google/Google SketchUp 6/Plugins/jointpushpull.rb:2378: syntax error>
          (eval):149]
          this is what came up when I did what you said in the ruby console. I am on a windows PC with Vista. the tools on surface is working good.
          Any suggestions are very much appreciated.
          • fredo6F Offline
            fredo6
            The file stored on Crai Depot contains a bug, for whatever reason. Sorry for that
            Please download instead from the Forum athttp://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=6708#p42783
            Fredo
              seanheadrick
              PERFECT thank you very much. I love SketchUp and all of ya'll that continue to make it ever better.
              • K Offline
                KAMELKH
                thanks for (jointpushpull) cause i have the this problem....but i want a resolve for( tools on surface) as fast as you can ....pleassssssssssse cause i have Graduation project and i use sketchup to do it cause sketchup is wonderfull....thanks
