    LightUp
    25 Posts 12 Posters 3.7k Views 12 Watching
    • BurkhardB Offline
      Burkhard
      Waiting for the new announcement of the updated Plugin from AdamB 😉
      Version 1.1c available incl. http://de.youtube.com/watch?v=MrM2Czpya_k
      [http://www.ia-plus.de(http://www.ia-plus.de)]
      • AdamBA Offline
        AdamB
        Can't ignore an opening like that!
        Yes, LightUp v1.1c is on the server and has many fixes and improvements. Come and get it, I think you'll be pleased with the improvements.
        Here a little video of the Sponza building processed by LightUp http://www.youtube.com/watch?v=KANx9iUqiWM which I thought was pretty neat even if I say so myself. 😄
        Adam
        • K Offline
          kwistenbiebel
          Wow Adam. That is pretty impressive. The Sponza looks great with Lightup. I know that is a rather big file so by the looks of it, LightUp does a good job.
          The ambient occlusion looks prety ok to me. Maybe a little messy in the darker parts (difficult for all render engines), but very good on direct lit surfaces.
          Looks like a nice improvement.
          Regards,
          Kwistenbiebel
            lewiswadsworth
            Just downloaded the new version, Adam. Thanks...this should be very interesting.
            col sporcar si trova
            • P Offline
              Phil Rader AIA
              I've downloaded it but I'll wait till I have more time to play with it.
              Looking forward to kicking the tires on this one.
              http://www.philrader.com
                remus
                LightUp for SketchUp
                Sketchup realtime lighting plugin
                LightUp for SketchUp (www.light-up.co.uk)
                • MALAISEM Offline
                  MALAISE
                  👍 really impressive this upgrade, thanks a lot. I try to simulate XRays scaterring in a box ( as far as XRay is also Light ...), it's very interesting to see the invisible..
                  😛 MALAISE ( from FRANCE )
                  • G Offline
                    gaganraj
                    this is great! 😍
                      remus
                      Any chance you could post some pics of your experiments malaise? it sounds very interesting.
                      • MALAISEM Offline
                        MALAISE
                        Hallo 😞 😕
                        Has someone feedback from the version LightUp v1.1c ?
                        At this moment, I can't use the sprite ( simulating small light source) which is turn into
                        texture despite the <$> facing the name. So I stay blocked when the rendering is made...
                        I 'll send some picture if I can solve that problem . Thanks Remus for your interest about
                        Xrays..
                        MALAISE (PAM)
                          mateo soletic
                          Thanks,
                          This looks great. I just downloaded it. Dont have time
                          right now but I will definately try it out.
                          [Concept Illustrations](http://concept-illustrations.com/)
                          • P Offline
                            putnik
                            AdamB, looks very interesting! Does it work in SketchUp 5? I couldn't find this on your web site (perhaps wasn't looking hard enought).
                            http://keshas.info
                            • AdamBA Offline
                              AdamB
                              Thanks.
                              No LightUp only supports SketchUp 6 (and higher!) because to integrate with SU nicely it uses WebDialogs and Observers.
                              Adam
                              • P Offline
                                putnik
                                Ok, thanks
                                http://keshas.info
                                  Jorgensen
                                  I have tree quite simple questions i guess
                                  How do you walk around like in the Sponza building ?
                                  When I try to walk I loose the lightning
                                  Is the light included when one export as AVI ?
                                  Is it possible to export 2d images containing the lights in a heigh resolution ?
                                  sketchup pro 2016 16.1.1449 64 bit | windows 10 pro | i7-3770k @3.5 GHz | 16gb ram | gtx 780 ti / gtx 980 ti | nvidia driver 368.39
                                  • jujuJ Offline
                                    juju
                                    Noticed that as well. I have the gravity switched on in the LU options and then navigate using that and scenes.
                                    Exporting animation with LU takes some time, the red line at the bottom of the screen is a progress bar (EDIT: just figured out it measures the time the demo has been loaded, once it reaches the righthand side of the screen SU locks up). Depending on your machine capabilities and the amount of scenes and lighting you have set you might want to go make yourself some coffee/tea/lunch/5 course meal while waiting. ... Oh lord it takes loooong, and I only had 3 scenes (using the LU studio skippy) to check the AVI export (and at a low viewport res at that!) so I can give you the correct answer. Sorry but the demo licence expired before the export finished. You know the demo licence only works for 30 minutes at a time then SU locks up.
                                    When you hit the enter/return button on your keyboard it takes a screenshot at 5x the resolution of your viewport. They're saved in TGA format and takes up quite a bit of space.
                                    Also have a look at the LU manual Adam put together. It's not complete by far, but it is quite useful.
                                    • K Offline
                                      kwistenbiebel
                                      That's funny:
                                      "come on now...need to be fast here...can't think...how much time left?..let's export..and...zzzoing....time's up" 🤣
                                        Jorgensen
                                        Hi Juju
                                        Thanks for your very usefull information.
                                        It's strange that it takes long to export as AVI, does it have to render the light for each frame ?
                                        Jorgensen
                                        • AdamBA Offline
                                          AdamB
                                          If you start the Tourtool and switch on Collision and Gravity you will be able to walk around buildings etc. It isn't the Sketchup Walk tool.
                                          LightUp completely replaces the Sketchup rendering so functions that save screenshot of Sketchup won't work. LightUp currently only supports saving high resolution screenshots that can be sampled down to a useable size in a PS, PaintShop Pro etc.
                                          Exporting movies from LightUp sounds like a useful feature for a future version though.
                                          Adam
                                          • AdamBA Offline
                                            AdamB
                                            At the risk of being a pedant, it doesn't "Lock up" Sketchup after 30 minutes. It times out and stops working but you can continue using SU as normal without LightUp for as long as you like.
                                            Adam
                                            • 1 / 2
