    LightUp
    25 Posts 12 Posters 3.8k Views 12 Watching
      remus
      http://www.light-up.co.uk/
      • MALAISEM Offline
        MALAISE
        👍 really impressive this upgrade, thanks a lot. I try to simulate XRays scaterring in a box ( as far as XRay is also Light ...), it's very interesting to see the invisible..
        😛 MALAISE ( from FRANCE )
          gaganraj
          this is great! 😍
            remus
            Any chance you could post some pics of your experiments malaise? it sounds very interesting.
            • MALAISEM Offline
              MALAISE
              Hallo 😞 😕
              Has someone feedback from the version LightUp v1.1c ?
              At this moment, I can't use the sprite ( simulating small light source) which is turn into
              texture despite the <$> facing the name. So I stay blocked when the rendering is made...
              I 'll send some picture if I can solve that problem . Thanks Remus for your interest about
              Xrays..
              MALAISE (PAM)
                mateo soletic
                Thanks,
                This looks great. I just downloaded it. Dont have time
                right now but I will definately try it out.
                Concept Illustrations
                  putnik
                  AdamB, looks very interesting! Does it work in SketchUp 5? I couldn't find this on your web site (perhaps wasn't looking hard enought).
                  http://keshas.info
                  • AdamBA Offline
                    AdamB
                    Thanks.
                    No LightUp only supports SketchUp 6 (and higher!) because to integrate with SU nicely it uses WebDialogs and Observers.
                    Adam
                      putnik
                      Ok, thanks
                      http://keshas.info
                        Jorgensen
                        I have tree quite simple questions i guess
                        How do you walk around like in the Sponza building ?
                        When I try to walk I loose the lightning
                        Is the light included when one export as AVI ?
                        Is it possible to export 2d images containing the lights in a heigh resolution ?
                        • jujuJ Offline
                          juju
                          Noticed that as well. I have the gravity switched on in the LU options and then navigate using that and scenes.
                          Exporting animation with LU takes some time, the red line at the bottom of the screen is a progress bar (EDIT: just figured out it measures the time the demo has been loaded, once it reaches the righthand side of the screen SU locks up). Depending on your machine capabilities and the amount of scenes and lighting you have set you might want to go make yourself some coffee/tea/lunch/5 course meal while waiting. ... Oh lord it takes loooong, and I only had 3 scenes (using the LU studio skippy) to check the AVI export (and at a low viewport res at that!) so I can give you the correct answer. Sorry but the demo licence expired before the export finished. You know the demo licence only works for 30 minutes at a time then SU locks up.
                          When you hit the enter/return button on your keyboard it takes a screenshot at 5x the resolution of your viewport. They're saved in TGA format and takes up quite a bit of space.
                          Also have a look at the LU manual Adam put together. It's not complete by far, but it is quite useful.
                            kwistenbiebel
                            That's funny:
                            "come on now...need to be fast here...can't think...how much time left?..let's export..and...zzzoing....time's up" 🤣
                              Jorgensen
                              Hi Juju
                              Thanks for your very usefull information.
                              It's strange that it takes long to export as AVI, does it have to render the light for each frame ?
                              Jorgensen
                              • AdamBA Offline
                                AdamB
                                If you start the Tourtool and switch on Collision and Gravity you will be able to walk around buildings etc. It isn't the Sketchup Walk tool.
                                LightUp completely replaces the Sketchup rendering so functions that save screenshot of Sketchup won't work. LightUp currently only supports saving high resolution screenshots that can be sampled down to a useable size in a PS, PaintShop Pro etc.
                                Exporting movies from LightUp sounds like a useful feature for a future version though.
                                Adam
                                • AdamBA Offline
                                  AdamB
                                  At the risk of being a pedant, it doesn't "Lock up" Sketchup after 30 minutes. It times out and stops working but you can continue using SU as normal without LightUp for as long as you like.
                                  Adam
                                  • jujuJ Offline
                                    juju
                                    That's funny:
                                    Yeh, laugh as much as you like KB, it was exporting the entire time until the demo time limit kicked in, and its not like I'm using a lightweight machine. Gathering from Adam's feedback, it looks like AVI export with LU scenes don't work currently. Probably why SU locked up on me then.
                                    BTW, in his guide Adam warns about LU being capable of corrupting a model. The LightUp studio file I used with the above attempt to export had something happen to it, the model just completely disappeared after that little test run, so make sure you have a backup of the file as suggested by Adam.
                                      kwistenbiebel
                                      Sorry to hear it messes up your model.
                                      As to .avi export: since LU is a baking app, doesn't it replace the textures with the new 'enlighted' ones? In that way, A .avi export should take the same time to export.
                                      But I guess it doesn't work that way...
                                      • AdamBA Offline
                                        AdamB
                                        I have to say I personally have never had a corrupt model from using LightUp. The only issue I've had - which sounds like what you've seen - is the model looking like its disappeared but its just the Layer is disabled.
                                        I'm certain your model disappearing is nothing more than the Layer being hidden.
                                        Adam
                                        • jujuJ Offline
                                          juju
                                          And right you are again sir! Layer hidden by some phantom gremlin. This helps to set ones mind at ease, but that little disclaimer still gives me the chills.
                                          • AdamBA Offline
                                            AdamB
                                            Its all very well you guys coming up with great ideas to improve LightUp, but I'm the one that has to write the code! 🤓
                                            Anyhow, its done. For the retail version of LightUp you can now press Shift+return in Tourtool mode and it will save frame sequences in realtime which you can crunch down into a movie with Cinepac/mencoder or whatever.
                                            Also fixed a bug in the current demo of LightUp (v1.1c) that prevented looping Animation working while in Tourtool, so that will be in the next release (v1.2a)
                                            Adam
